PENGUIN ROBOT Holiday Gift - 210 Programs
Penguin Robot Holiday Gift - 210 Programs
Almost a year in the making, these programs
incorporate the new VIRTUAL SOUND CHIP (VSC).
Unzip the attached file to gain 210 Penguin programs,
ready to run.
The VIRTUAL SOUND CHIP - VSC is a virtual reality (VR)
computer chip, created entirely from software. It has no
physical size, weight, or dimensions - and takes up no space
outside of microcontroller EEPROM and RAM. It synthesizes
multiple channel sound waveforms, resulting in special effects
sound and music generation. It can make unlimited sound
variations, emulate and mimic numerous real world sounds,
and go beyond the real world by creating music tempos, echo
chambers, reverb, dimensions and thousands of amazing special
effects.
The VSC is fully functional and tested with up to eleven
channels of sound mixing control, although the waveform levels
can be expanded. Consult the amazing list of over 200 Virtual
Sound Chip supporting programs released with this new concept.
The VSC Chip turns the microcontroller, which previously could
only make a few beeps and simple notes, into something truly
wonderful!
humanoido
ready to run.
effects.
wonderful!
humanoido
' The Penguin VIRTUAL SOUND CHIP - VSC is a multiple channel ' sound synthesizer and special effects sound and music generator. ' It can make unlimited sound variations, Penguinese, and things like ' music tempos, echo chambers, reverb sounds, jet engines, motors, ' and hundreds of amazing sound effects. Up to eleven tested channels ' of sound mixing control.
without the extension. Just add the dot zip and the file will
return to standard format. VIRTUAL.zip
This will expand into a folder: VIRTUAL SOUND CHIP 210 PROGRAMS
and opening that folder will reveal 210 named folders, with a program
in each folder.
humanoido
