PropTool Compiler Bugs — Parallax Forums
hippyhippy Posts: 1,981
edited 2007-12-26 12:51 in Propeller 1
Propeller Tool 1.05.08
CON
  FINAL = $1E0
DAT
REGISTERS              long    0[noparse][[/noparse] FINAL-$ ]
REGISTERS_END
Works fine for any FINAL < $1F0, fails for FINAL == $1F0. Mouse click on REGISTERS_END shows Cog Address as expected when < $1F0, at $1F0 it shows N/A, and trying to use "FIT REGISTERS_END" gives an "Address out of range" error.
ORG $1F0 is accepted but ORG $1F1 isn't. Either both should be accepted or both rejected.
I personally cannot see any reason why a Cog Address Label shouldn't be allowed a value greater than $1EF.
  • RaymanRayman Posts: 16,374
    edited 2007-12-26 01:56
    That $ thing is new, right? Guess that returns the current address...
    This is over my head! What in the world are you trying to do?
  • deSilvadeSilva Posts: 2,967
    edited 2007-12-26 02:20
    hippy said...
    CON
      FINAL = $1E0
    DAT
    REGISTERS_END
    I could not reproduce this issue with Version 1.05.8 Can you please give the EXACT code that fails?
    said...
    In fact both are useless. But is does no harm...
    said...
    You cannot allocate ANYTHING at or above $1F0 in the COG; if you need reference to an address >= $1F0 you can use the CON section. I agree it could be nice to say:
    ORG $1F00
    firstSpecialRegister  RES 1
    Post Edited (deSilva) : 12/26/2007 2:27:25 AM GMT
  • hippyhippy Posts: 1,981
    edited 2007-12-26 03:01
    Exact code ...
    CON
      FINAL = $1F0
    PUB Main
    DAT
    REGISTERS_END
                            fit REGISTERS_END
    Take the 'fit' out to see the N/A Cog Address for REGISTERS_END.
    It's fair enough to not be able to allocate above $1EF, but I don't see why a label can't have any value. This bit me because the code was working, then I decided to relocate it to the end of Cog and the compiler objected. I can change it, but if I move it again I need to change it again.
    edited 2007-12-26 03:11
    (a) I see.. But REGISTERS_END IS "out of range"
    DAT
    REGISTERS               long    0[noparse][[/noparse] $1f00 ]
    REGISTERS_END
                            fit REGISTERS_END
    I think this a good error message...
    (b) what do you mean by "relocate to the end of COG"? So you want to have something as I gave in my example above?
    ORG $1f00
    lastResort  RES 16
    I think this will be not a good idea...
    edited 2007-12-26 10:51
    deSilva said...
    If I replace "fit REGISTERS_END" with "fit $1F0" it works, and "org REGISTERS_END-1" is in range, if the compiler had assigned $1F0 to the label. The root issue is the compiler marking the label at $1F0 as invalid rather than checking for the validity of org/fit addresses when evaluated.
    deSilva said...
    Yes, but the resultant org would be in range, below $1F0.
    An similar situation as with ...
    ADDRESS EQU  $+$12345678
            ORG  ADDRESS-$12345678
    myVar   long 0
    Post Edited (hippy) : 12/26/2007 11:00:41 AM GMT
    edited 2007-12-26 11:45
    The issue is related to local variables discussed elsewhere so here's ( near actual ) code which shows the problem I face. This works -
    DAT
                  org       $000
    :Loop         call      #MySub1
                  call      #MySub2
                  jmp       #:Loop
    REGISTERS     long      0[noparse][[/noparse] 16 ]
    REGISTERS_END
    MySub1        mov       :a,:count
                  jmp       #:Return
    :org          org       REGISTERS
    :a            res       1
    :count        res       1
                  fit       REGISTERS_END
                  org       :org
    :Return
    MySub1_Ret    ret
    MySub2        mov       :a,:increment
                  jmp       #:Return
    :org          org       REGISTERS
    :a            res       1
    :increment    res       1
                  fit       REGISTERS_END
                  org       :org
    :Return
    MySub2_Ret    ret
    Now if I make MySub1 and MySub2 overlays it also works, but if the Overlay or other routines grows such that RESISTERS_END falls on $1F0, although the program is still valid, it cannot get through compilation ...
    DAT
                  org       $000
    :Loop         call      #Overlay
                  long      MySub1
                  call      #Overlay
                  long      MySub2
                  jmp       #:Loop
    Overlay       mov       ovlPtr,Overlay_Ret
                  long      0[noparse][[/noparse] 215 ]
    Overlay_Ret   ret
    ovlPtr        long      0
    OVERLAY_START long      0[noparse][[/noparse] 256 ]
    OVERLAY_END
    REGISTERS_END
                  org       OVERLAY_START
                  jmp       #:Return
    :org          org       REGISTERS
    :a            res       1
    :count        res       1
                  fit       REGISTERS_END
                  org       :org
    :Return
    MySub1_Ret    ret
                  fit       OVERLAY_END
                  org       OVERLAY_START
                  jmp       #:Return
    :org          org       REGISTERS
    :a            res       1
    :increment    res       1
                  fit       REGISTERS_END
                  org       :org
    :Return
    MySub2_Ret    ret
                  fit       OVERLAY_END
    The 'long 0[noparse][[/noparse] 215 ]' would in reality be executable instructions. Note REGISTER_ENDS is at $1EF. Change that to 'long 0[noparse][[/noparse] 216 ]' and the compiler errors.
    edited 2007-12-26 12:19
    Hippy, mayby I do not see your point....
    To my understanding the PropellerTools tries to help you as much as it can to not overcrowd the COG.
    It has not so many clues for that as it will rarely know if it's a HUB data allocation or a COG allocation you are designing.
    The tool takes three chances:
    (1) When asked to check the actual COG address counter against a specific value using FIT
    What you encountered was the situation
    FIT N/A
    leading to the error message.
    The label REGISTERS_END is outside the allowed region of COG memory allocation, and is thus assigned N/A rather than $1f1. It is of little concern that you do not allocate things to it... It has be be $1f1 ... and that would be not good...
    This makes terribly much sense to me.
    (2) When allocating memory by RES n. It is hard checked that the last reserved word fits into $1f0
    (3) When a label is used within an instruction which is N/A, i.e. COG address =>$1f0. I can imaging that this check was the main rational for introducing N/A in the first place
    I always wondered why it does not check the allocation of instructions above $1ef as such; e.g. is is perfectly valid to write
    org $1ef
    nop
    nop
    Edit: A work around?
    What about
    REGISTERS     long      0[noparse][[/noparse] 15 ]
    LAST_REGISTER long 0
    rather than
    REGISTERS_END
    Post Edited (deSilva) : 12/26/2007 12:27:25 PM GMT
    deSilva said...
    On one hand, perhaps, but then on the other it is often entirely lax and allows the programmer to do what they want without care as to right and wrong. I suppose I'm in the minority here, complaining about the PropTool not allowing me to do something given the number of 'mistake's people have complained of which the PropTool lets through without flagging an error.
    deSilva said...
    What about
    MANY THANKS : "fit LAST_REGISTER+1" works in all cases. roll.gif
