USB Servo Controller Problems — Parallax Forums
Jake11611Jake11611 Posts: 47
edited 2007-12-26 02:54 in General Discussion
I got a USB servo controller this morning for Christmas. I wired it up with 6 volts for the servos' power supply, and hooked it up to a BOE, but the code for in the manual that checks the firmware just ends up looking for the PSC, and doesn't find it (says PSC ver:, with·three characters afterwards)· I also noticed that the servos hooked up to the right side of the board are·now moving. The ones on the left side move less, but are·still turning.·I also tried·using the software from the site, but that isn't helping either. ·
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2007-12-25 22:51
    Is your USB serial port showing up in device manager when you hook it up to the PSC·and does the baud match the baud in your sample program. Can you post the code you are using.
    Jeff T.
  • Jake11611Jake11611 Posts: 47
    Nevermind, I just looked at the PSC software and I had the wrong COM port checked. rolleyes.gif· Thanks for the reply, though.
