HB25 start up... question and perhaps a solution.
I got my HB25 they work great all is well, but in order to get them to work I have to cycle the power to the motors (not the HB25) this was expected as per the documentation. I however do not want to have do this every time I start up this bot, especially since I want it to be web controlled.
First off this is normal right? I'm not providing the proper start up time for the HB25 so I need to reset the power to the motors to make up for it.
My thoughts, I want to run the power through the NC side of a relay, and the first thing this bot will do is to activate the relay pulling the connection open. (resetting the power) after a few other items have been run allowing the start up time, I can shut off the relay the motors should work and no extra power is used to for the relay. Sound like a good idea? too simple? to complicated? any thoughts?
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
DGSwaner
I was thinking about doing something similar with my HB25s so that the whole system can be powered up using one switch and include the delay required for the HB25. So, I do think this is a good idea... Although I have no technical advice to offer you, I do have a question. What type of relay are you planning on using? I cannot seem to find one that will work with the voltage of the stamp and switch the voltage required for the HB25... any ideas?
thanks
david bowen
The problem (=size/volume/weight) of relais is not so much the swiched voltage but current. 120VAC works with many (in contrast to the 220V in Europe where 1/2 of nice relais cannor be used, as they are rated for 120VAC only.)
"Solid state" relais have a different price tag...
DGSwaner
Though the coil impedance is around 1k for a low power 12 V relais, it goes down to 100 or even lower for 16 A relais.
But many transistors can drive 300 mA; that needs no special selection...
