bit shifting a 48bits number
Does anyone know a more elegant/better way to scale a 48bit number to a 32bit number?
· 'at this point responseBuffer[noparse][[/noparse]0] to responseBuffer[noparse][[/noparse]5] is filled, responseBuffer[noparse][[/noparse]0] is LSB
· if power2 == 0 'report bytes
··· if responseBuffer[noparse][[/noparse]4] <> 0 or responseBuffer[noparse][[/noparse]5]<>0 'bytesize is larger than 32bits
····· return -1
· if power2 == 10 'report kilobytes
··· responseBuffer[noparse][[/noparse]0] := responseBuffer[noparse][[/noparse]1]· 'shift 8bits
··· responseBuffer[noparse][[/noparse]1] := responseBuffer[noparse][[/noparse]2]
··· responseBuffer[noparse][[/noparse]2] := responseBuffer[noparse][[/noparse]3]
··· responseBuffer[noparse][[/noparse]3] := responseBuffer[noparse][[/noparse]4]
··· responseBuffer[noparse][[/noparse]4] := responseBuffer[noparse][[/noparse]5]
··· responseBuffer[noparse][[/noparse]0] := (responseBuffer[noparse][[/noparse]0] >> 2) | (responseBuffer[noparse][[/noparse]1] << 6)· 'shift 2bits
··· responseBuffer[noparse][[/noparse]1] := (responseBuffer[noparse][[/noparse]1] >> 2) | (responseBuffer[noparse][[/noparse]2] << 6)
··· responseBuffer[noparse][[/noparse]2] := (responseBuffer[noparse][[/noparse]2] >> 2) | (responseBuffer[noparse][[/noparse]3] << 6)
··· responseBuffer[noparse][[/noparse]3] := (responseBuffer[noparse][[/noparse]3] >> 2) | (responseBuffer[noparse][[/noparse]4] << 6)
· if power2 == 20 'report megabytes
··· responseBuffer[noparse][[/noparse]0] := responseBuffer[noparse][[/noparse]2]· 'shift 16bits
··· responseBuffer[noparse][[/noparse]1] := responseBuffer[noparse][[/noparse]3]
··· responseBuffer[noparse][[/noparse]2] := responseBuffer[noparse][[/noparse]4]
··· responseBuffer[noparse][[/noparse]3] := responseBuffer[noparse][[/noparse]5]
··· responseBuffer[noparse][[/noparse]0] := (responseBuffer[noparse][[/noparse]0] >> 4) | (responseBuffer[noparse][[/noparse]1] << 4)· 'shift 4 bits
··· responseBuffer[noparse][[/noparse]1] := (responseBuffer[noparse][[/noparse]1] >> 4) | (responseBuffer[noparse][[/noparse]2] << 4)
··· responseBuffer[noparse][[/noparse]2] := (responseBuffer[noparse][[/noparse]2] >> 4) | (responseBuffer[noparse][[/noparse]3] << 4)
··· responseBuffer[noparse][[/noparse]3] := (responseBuffer[noparse][[/noparse]3] >> 4)
· free.byte[noparse][[/noparse]0] := responseBuffer[noparse][[/noparse]0]
· free.byte[noparse][[/noparse]1] := responseBuffer[noparse][[/noparse]1]
· free.byte[noparse][[/noparse]2] := responseBuffer[noparse][[/noparse]2]
· free.byte[noparse][[/noparse]3] := responseBuffer[noparse][[/noparse]3]
· return free
regards peter
····· return -1
· return free
regards peter
Could BYTEMOVE help with the first part? Is long alignment out of the question?
Tracy Allen
www.emesystems.com
VAR
· byte SPI_CS··· 'chip select· - connects to Datalogger pin CS
· byte SPI_CLK·· 'clock output - connects to Datalogger pin SCLK······
· byte SPI_SDI·· 'data input·· - connects to Datalogger pin SDO
· byte SPI_SDO·· 'data output· - connects to Datalogger pin SDI
· byte responseBuffer[noparse][[/noparse]BUFSIZE]
Does the VAR section always start at a long boundary?
Or should I define
VAR
· long dummy
that way responseBuffer is known to be at a long boundary.
regards peter
Space saving:
· repeat while power2/10 > 0
··· responseBuffer[noparse][[/noparse]5] := 0
··· responseBuffer[noparse][[/noparse]4] := (responseBuffer[noparse][[/noparse]4] >> 2)
··· power2 -= 10
· if responseBuffer[noparse][[/noparse]4] <> 0 or responseBuffer[noparse][[/noparse]5]<>0 'size cannot be represented by·32bits
··· return -1
· return free
This is somewhat better I guess.
regards peter
· repeat·power2/10
··· repeat i from 0 to 4
····· responseBuffer[noparse][[/noparse]i] := responseBuffer[noparse][[/noparse]i+1]· 'shift 8bits
····· responseBuffer[noparse][[/noparse]i] := (responseBuffer[noparse][[/noparse]i] >> 2) | (responseBuffer[noparse][[/noparse]i+1] << 6)· 'shift 2bits
··· power2 -= 10
··· return -1
· return free
regards peter
· repeat·power2/10
··· bytemove(@responseBuffer,@responseBuffer+1,5)
··· power2 -= 10
··· return -1
· return free
That works. I will upload my DataloggerSPI object shortly where this is part of.
Thanks.
regards peter
