byte pointer memory access
David Betz
I've been trying to write some simple SPIN code to access an array of bytes through a pointer and am having some trouble understanding the difference between the two methods of doing this. I've been trying to use the following code. It seems that test2 does what I expect but test1 does not. Shouldn't they be equivalent?
Thanks!
David
VAR
byte data[noparse][[/noparse]10]
long ptr
PUB init
ptr := @data
test1(2)
test2(3)
PUB test1(i)
ptr.byte := 1
PUB test2(i)
byte[noparse][[/noparse]ptr] := 1
Thanks!
David
VAR
long ptr
PUB init
ptr := @data
test1(2)
test2(3)
PUB test1(i)
ptr.byte := 1
PUB test2(i)
No they shouldn't.
ptr.byte is accessing the least significant byte of the actual pointer. Same as ptr.byte[noparse][[/noparse]0] would do.
byte[noparse][[/noparse]ptr] is accessing the byte that ptr is pointing to.
Help to build the Propeller wiki - propeller.wikispaces.com
Play Defender - Propeller version of the classic game
Prop Room Robotics - my web store for Roomba spare parts in the UK
Is it not this simple ?
var
byte x
pub read_em_all | ptr
repeat 10
x := byte [noparse][[/noparse] @data ] [noparse][[/noparse] ptr++ ]
'do something with x
I can't even imagine what is going on here........."ptr.byte" , I will leave that to others
Ron
I have not the slightest idea what you are on to... You use an over-complex construction; and please note that ptr is NOT initialized to zero!!!!
X.BYTE[noparse][[/noparse]n] is someting you do with the "special registers" as
OUTA[noparse][[/noparse]8*n .. 8*n+7]
Post Edited (deSilva) : 12/24/2007 6:34:39 PM GMT
Another probably dumb question:
How do I continue a statement on a second line. For instance, I'd like to split up some of my method calls over several lines if they have a lot of parameters.
foo(a,b,c,d)
becomes
foo(
a,
b,
c,
d)
or something like that. Is this possible?
foo( { } a, { } b, { } c, { } d)Not really aesthetic... But it comes handy for commenting things on that opportunity
Welcome to the land of indention-sensitive syntax!
Nick, not a friend of the above! No, really not!
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
