USB Identification Issue
Hi. I am pretty new to the Basis Stamp 2 (with the Board of Education) and am trying to get my device to connect to my laptop for the first time. I get a "No Basic Stamp Found" error, but on COM4, it does not display a Device Type or Version number, but it does say Yes to both Loop Back and Echo. This is a USB connection to my computer (I bought this through the BOE Bot kit). The USB cables are as firmly connected as possible and I have tried downloading the lastest software from the website, but nothing has changed. And I have tried restarting my computer, but that didn't do anything either. Finally, the batteries are fully charged and I have tried to reseat the chip. Does anybody have any ideas? This is kinda frustrating.
Click on Start button
Select control panel,printers and other hardware
in the see also box select system
select hardware,device manager,ports
enter the com port number noted by the run, identify test
select port settings, advanced
uncheck the box labled "use FIFO Buffers" then click OK
click OK to close each window as needed to return to the basic stamp editor
try downloading the program once more
Hope this helps- electromanj
