Transistor Help
I need a BS170 Transistor to use as a switch to power a DC motor from My BS2 however the only place I can find it is on the Parallax web site.· would buy it from there however with shipping it makes it a little too pricey. My question is: Is there an equivelent to this transistor that may be more easily found?
[noparse][[/noparse]Tim]
1) The maximum collector-emitter voltage. This should be significantly higher than the maximum voltage to be switched.
2) The maximum collector current. This should be higher than the maximum current to be carried when turned on.
Other specs may be important in certain circumstances, but, for switching LEDs or relays or motors, these are the important ones.
If you're going to be switching more than a couple of hundred milliAmps, you will probably need to pay attention to the kind of package
the transistor has and whether it's capable of dissipating enough heat. You may want to use a power transistor that is physically designed to handle more heat (usually a TO220 package ... with the big tab).
3) Collector-emitter saturation voltage at your working current.
By multiplying the saturation voltage by the working current, you arrive at the power dissipation. This can be used to determine whether a heatsink is necessary or if the transistor is even usable in your app.
Also:
4) Minimum current gain (beta) at your working current.
By dividing your working current by the minimum current gain, you can determine the minimum base current required to switch the transistor "on". This will help in figuring out the required series base resistor value [noparse][[/noparse] R = (input voltage - 0.6) / minimum base current ] or whether you need to add a gain stage just to drive the base adequately.
The examples on page 86 use a 2N3904 and a base resistor of 1K.
Post Edited (Mike Green) : 12/21/2007 11:16:20 PM GMT
I just have one more question. In the configuration I mentiond, would I need to worry about damaging the BS2 I/O PIN's?
2) You do need the reverse connected diode across the relay coil as shown in the Industrial Control tutorial. The transistor may eventually be damaged if you leave that out.
3) The 470 ohm resistor protects the I/O pins by limiting the current to a maximum of about 10ma (approx: E (5V) = I (10ma) x R (470ohm)).
