SEROUT CPmmand Sound PAL
SEROUT iopin, reset, [noparse][[/noparse]0]········· page 4 of SoundPAL datasheet.
What is the [noparse][[/noparse]0] ? The write up seems to state 'Output 9 low bits at 1200 baud.
From the HELP file [noparse][[/noparse]0] seems to be the outputdata. Is this saying output the data as a 0?
SEROUT Tpin {\Fpin}, Baudmode, {Pace,} {Timeout, Tlabel,} [noparse][[/noparse]OutputData]
OutputData† is list of variables, constants, expressions and formatters that tells SEROUT how to format outgoing data. SEROUT can transmit individual or repeating bytes, convert values into decimal, hex or binary text representations, or transmit strings of bytes from variable arrays. These actions can be combined in any order in the OutputData list.
Chuck Thomas
Chuck Thomas
The SoundPAL resets when its I/O pin is held low for a certain period of time. Sending a zero byte (a low startbit, plus eight more consecutive low bits) at a slow baud rate is just a convenient way to pulse the pin low and restore it to an input when finished (via the open baudmode setting).
If the [noparse][[/noparse]0] were changed to [noparse][[/noparse]1] would it then send out 9 high bits?
Thank you,
Chuck
To transmit all high bits, you'd send $FF. But, again, it you looked at the signal with a scope, all you'd see is one low bit (the start bit), since the following high data bits and the stop bit are the same as the default marking state.
Post Edited (Phil Pilgrim (PhiPi)) : 12/21/2007 6:39:21 PM GMT
