Switching between 5MHz and 6MHz
![hippy](https://forums.parallax.com/uploads/userpics/339/nR1DFKQUWXIHE.jpg)
Anyone any good ideas on switching between a 5MHz and 6MHz crystal at run-time ? I've done similar manually in the past with both in series and a SPDT switch to short across one or the other but was wondering about more program controlled ways.
The best I can think of is two oscillator modules and a one-of-two selector, or a single 30MHz divided down by 6 or 5.
Would an SPDT switch work with a Propeller ( ProtoBoard ) or do the crystal leads need to be particularly short ? It worked okay with a Hitachi 6301 4MHz/8MHz.
The software would need to be changed slightly anyway, as the program needs a declaration of crystal speed, pll etc, so changing the crystal also would require a change in code.
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
I'd like to write my own 'not to be published' code for 96MHz but appreciate most published code should be written for 80MHz ( the commonest used ) so it was an idea that I could switch between either without having to worry about the hardware and could use the same hardware for both.
