Help with ADC data
Ok so I'm doing some data logging use the BS2 stamp and an 8 bit ADC. Basically I need to program to bring in the data from the ADC that tells me Potential of a battery pack in a circuit. When it reaches a certain point I need the program to stop running.
Right now the program reads in the data from the ADC fine. It gives me an 8bit binary value. I can convert that outside the program and figure out the voltage easily. However I need the program to be able to convert the 8bit binary value into a decimal value so I can use a DO UNTIL loop and have it end when the potential reaches 2 volts. Otherwise the test destroys the batteries as it runs indefinitely.
Any help will be greatly appreciated.
volt = binary value * 50 / 255
This will give you a reading of 0 to 50 tenths of a volt, so 2V would be 20.
-Martin
SelmaWare Solutions - StampPlot GUI for controllers, XBee and Propeller Application Boards
Southern Illinois University Carbondale, Electronic Systems Technologies
Basically the code reads a binary value in from the adc to a variable adcBits.
adcBits is a 8bit binary value originally but I need to convert it to a decimal value, at least, from what I understand.
- Stephen
Basically if I have, when adcBits is an 8bit binary...
DO UNTIL (adcBits * 5/256 <2)
blah blah
blah
LOOP
It should loop until my circuit dips below two volts?
