Pin crimping tool.... — Parallax Forums
GarthGarth Posts: 18
edited 2007-12-18 16:25 in General Discussion
Does anybody have a source for pin crimping tools? The style of pin I'm looking for is what you would find on the PIR sensor (the I/O). And I'm also trying to a molex crimper that doesn't cost an arm and three legs. freaked.gif
Thanks in advance.
Garth
  • DgswanerDgswaner Posts: 795
    edited 2007-12-18 15:17
    I crimp all my molex ends with a wire striper/cutter the cheap kind with a < > notch in either side I found that this works better than needle nose pliers. I also solder just in case. I don't think there is a cheap Molex crimper on the planet but I would also like to know where to find one if there is.
    "A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
    DGSwaner
  • JonnyMacJonnyMac Posts: 9,767
    edited 2007-12-18 15:45
    You can get the parts you need from Jameco.com:
    #100766 -- female crimp pin
    #100812 -- 2-pin shell
    #157382 -- 3-pin shell
    #159266 -- crimper tool
    Post Edited (JonnyMac) : 12/18/2007 3:58:14 PM GMT
  • GarthGarth Posts: 18
    edited 2007-12-18 16:17
    Yea! Thank you very much!
    They also have the Molex crimp tool #304928
