Serial Port on BOT is causing a problem????
I'm using a bluetooth serial adapter on my BOE-BOT or trying to...
Every time I try to identify or send a firmware to it - the adapter(the part plugged into the serial port on the bot) resets.
I've tested all individual components of the issue and they all work as advertised.
I confirmed I could "talk" to the BOE w/a regular serial connection and I've also confirmed the Bluetooth Dongle AND Bluetooth serial port adapter work with other stuff fine.
I've confirmed the Baudrate/Bits/Parity/Stopbit settings are good.
There is something different about the BOE serial connection that is causing the bluetooth issues.
Oddly - when i send commands from a VB app I wrote - it doesn't reset the bluetooth adapter but the commands don't make it....In fact - i noticed when i did a Hyperterminal loopback that all the commands I sent waited in a buffer and the dumped to the Hyperterminal screen as soon as I connected.
Is there a DB9 pin that the Serial Port adapter might not be dealing with?
I would appreciate any wisdom [noparse]:)[/noparse]
- Stephen
I'm starting to think it may be a limitation of the adapter - but the sales lit says specifically it's good for using with GPS serial adapters. I find it hard to believe it won't work with Garmin - they are like the #1 GPS seller....
I'm testing this solution...I'll post the results...
If I short pin 7 to 8 AND 2 to 3 THEN establish the connection between my bluetooth dongle and the bluetooth serial port adapter BEFORE plugging the adapter into the serial port - I can send commands to the BS2.
Apparently the GBS301 fully implements the RS-232 spec. as stated in the link above.
