DS18S20 code sample wanted — Parallax Forums
stamptrolstamptrol Posts: 1,731
edited 2007-12-18 00:39 in BASIC Stamp
·Hello folks,
··· I'm changing a temperature monitoring system from the DS1620 (3 wire shiftin/shiftout) to the DS18S20 (1-wire).
··· I'm using the BS2px with 1-wire support.
··· I know I've seen a sample piece of code somewhere, just can't find it!
··· Can anyone point me in the right direction?
·Thanks,
·Tom
Tom Sisk
http://www.siskconsult.com
  • phil kennyphil kenny Posts: 233
    edited 2007-12-17 14:33
    Is this it?
    http://forums.parallax.com/showthread.php?p=642254
    phil
    Post Edited (phil kenny) : 12/17/2007 2:40:24 PM GMT
  • stamptrolstamptrol Posts: 1,731
    edited 2007-12-17 15:30
    Phil,
    Thanks for that! It should work just fine.
    Tom
    Tom Sisk
    edited 2007-12-17 18:06
    Tom be carefull with the part numbers. Dallas Semi has a habit of using similar or even identical part numbers for devices that have important differences in programming. The difference between the DS1820, DS18S20 and the DS18B20 is a case in point. The most state of art device in the family is the DS18B20, which always returns the high resolution (12 bit signed) value while the earlier ones were 9 bits unless you went to extra trouble to read the high resolution registers. Code written for the "B" will not work on the "." and the "S" and vice versa.
    Tracy Allen
    www.emesystems.com
    Thanks Tracy,
    I had noticed the 9-bit vs 12-bit issue.
    I got the code working with the ds1820 after finding a damaged ds18s20.
    Tom Sisk
