Regulators... Where can I get them?
Hey, I've been experimenting with the propeller for a couple of weeks now and have even interfaced an LCD module with it. Besides the BS2SX, this is my first real microcontroller experiment. I briefly used the BS2SX a month or so ago and quickly outgrew it's capabilities. I recently got the prop education board and it's great - until you blow the regulator.
Just a couple of minutes ago, I was using·the prop and a pwm signal and a large 12v dc lead-acid battery. Apparently, this is a deadly combo when your messing around with wires will everything is connected. Needless to say, I think I touched the positive lead from the battery to one of the leads on the 5v regulator. I tried firing the prop up, but nothing happens. I'm pretty sure I toasted the 5v. Regulator, and probably the 3.3v regulator since I just replaced the 5v. The only problem is, I don't have any 3.3v regs. on hand.
Anyone know where you can get these for cheap? I looked on ebay, but they're all surface mount. I don't want to pay $8 shipping through mouser or something for such a small part.
Thanks!
Thanks!
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
*Peter*
LF 33 (1A)
LM 1084 (5A)
LM 1085 (3A)
LM 1086 (1,5A)
LM 3940 (1,5A)
LM 2937 (0,5A)
Note that they have different pin-outs, either IN/GND/OUT (as expected) or GND/OUT/IN
Also note the current rating generally means "with heatsink"
