Midi Player? — Parallax Forums
Midi Player?
RaymanRayman Posts: 15,890
edited 2007-12-16 23:21 in Propeller 1
I'm thinking about doing a MIDI player for the Prop...· But, don't want to re-invent the wheel here...
(Probably starting with just one or two channels and sine waves...)
Has anybody already done this?
  • hippyhippy Posts: 1,981
    edited 2007-12-15 14:06
    That's really a bolt-on on top of the Sound Synthesiser stuff I was doing.
    MIDI is the potentially easier part, creating the sound synthesiser is more involved; VCO's, ADSR's and patching. Plus allocating notes to different sound generating channels if you want polyphonic sounds.
  • Spork FrogSpork Frog Posts: 212
    edited 2007-12-15 14:08
    If you want simpler MIDI, check out HDMF in the Hydra forum, which all input files are MIDIs, then converted to another format for easier use on the Prop.
  • PyrotomPyrotom Posts: 84
    The MIDI part is easy - check out the MIDI In object I posted to the object exchange...
