matlab and basic stamp 2 interface problems..
hi folks,
i'm trying to interface matlab to my BS2 and if it works, will blink
an LED
bs2 code :
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM1}
status_pin VAR Word
main:
SERIN 16,84,[noparse][[/noparse]DEC status_pin]
IF status_pin = 0 THEN LOW 8
IF status_pin = 1 THEN repeat
GOTO main
repeat:
PAUSE 500
HIGH 8
PAUSE 500
LOW 8
GOTO repeat
%matlab code :
status_pin = 1;
s=serial('com1')
set(s,'baudrate',9600)
set(s,'terminator','CR')
fopen(s);
fprintf(s,'%s\d',[noparse][[/noparse]status_pin]); %if data is sent, i should see the LED
blinking once this line is executed am i rite??
fclose(s)
any ANY help is very much appreciated..really frustrated with such a
simple code but nothing seems to work?!
an LED
bs2 code :
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM1}
status_pin VAR Word
main:
GOTO main
repeat:
PAUSE 500
HIGH 8
PAUSE 500
LOW 8
GOTO repeat
%matlab code :
status_pin = 1;
s=serial('com1')
fopen(s);
fclose(s)
Hope that helps put you on track
Jeff T.
How do you know when it's inverted and not true? In this example, how did you know?
