newb question, could someone explain to me why the ServoPAL is necesary?
Parallax is selling this device called the ServoPAL that sits inline between the basic stamp and a servo continually sending pulses.· So one pulse is sent from the Basic Stamp and the ServoPAL keeps sending that pulse to the servo until another pulse is received from the Basic Stamp.· I was under the impression that with regular servos one pulse was sufficient to set it to a position AND maintain that position until another pulse was recieve.· I guess this might be usefull with a continuous rotation servo since those turn a certain amount with each pulse.· I guess my question is if I want to have a regular servo maintain a certain position against load do I need to keep pulsing or is one pulse sufficient.
Unfortunately, thats not quite accurate. On a continuous rotation servo, the pulse length tells the servo a direction and a speed, not the amount to turn. For that, you'll need an wheel encoder.
Craig
I have a duel boot of Ubuntu Linux and Windows Vista. Vista, because it came with the PC, Ubuntu because I like software that works.
"If Python is executable pseudo code, then Perl is executable line noise."
"Failure is not an option -- it comes bundled with Windows."
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Windows for Solitaire
