Does each Toddler have it's own personality?
·· I was running the 'first steps using tables' program and noticed my Toddler when finished was pointing at a roughly 45 degree angle from when·he started.· So·he was making a slow circle as·he was moving.· I can see·he looks as though·he is tilting to one side more then the other, which would no doubt cause him to turn like that.· I can't see anything wrong with him mechanically, so I was wondering if each Toddler has his own 'personality', that is do you find you need to tweak the stock programs to have your Toddler move as it should?· Have other people noticed their Toddlers 'wandering off' like mine does?·
Thanks!
[noparse][[/noparse]Tim]
Thanks!
Maybe the rods between servos and feet are sligthly different in lenght, and this is causing the curious behaviour.
Dave
Dave Andreae
Parallax Tech Support·
·· Also have a question about the plastic wire keepers on the legs.· The manual says to keep them loose enough, but I have mine really tight.· Before they were loose, but were moving up and down too much, I thought.· Could having them too tight cause a problem?
Thanks!
