Basic stamp controller interface board- power requirements
I'm looking at the StampCi (item# 27945) board for some light automation projects at my job. Looking through the manual, I noticed that the power requirements are 9-12v 1000ma max. I also noticed that it uses a LM2937 regulator that, per the spec sheet I found at Digi-key, differs in that it says it can handle 26v (500ma max).
We have LOTS of 24v power supplies. I'd like to use them, which leads me to my question:If I keep the current across the board to <500ma can I safely run it at 24v? Or are there other limiting factors I'm not seeing?
Also, how does the life span of this product look? I don't want to start using it·if it's close to obsolesence.....
Thanks in advance,
Slater
Thanks in advance,
Slater
Parallax tends to keep products that they make themselves around for as long as there's a demand for them.
Slater
