UnsignedIntMath.java problem in umulf fonction
What is this command in method umulf (row 125):
public static int umulf(int value, int fraction) {
int i, result=0, rest=0;
for (i=1; i<17; i++) {
if (fraction < 0) { //b15 set
result += (value >>> i); //accumulate integer result
rest += ( (value & ((1<<i)-1)) << (16-i) ); //accumulate rest R/65536
if (CPU.carry()) result++; //update result if rest overflows
fraction <<= 1; //next bit
if (rest < 0) result++; //roundoff
return result;
I think the method doesn't work...
return result;
(add two postive numbers,·subtract two negative numbers) generates an overflow.
If you have an example where umulf generates the wrong result, please post it.
regards peter
