BS2px
Hey,
What could be the problem if the v-reg on the stamp gets too hot? I am only using a nine-volt battery.
Only two reasons I can think of:
1. Too great a load on the v-reg output.
2. A short in your wiring.
Bruce Bates
It is unlikely that you have a short in your Stamp. Most likely it is something external attached to it.
If you actually have a short in your Stamp, it is possible it would still work unless you happened to use the I/O pin with the short.
We'll all be more than willing to assist you, but you're giving us the barest minimum of information to work with. You have to let us "see", exactly what you see, since we're obviously not there at your workbench. Here are a few questions that may help us to get on the right road:
1. Under ordinary circumstances, any PBASIC Stamp must be "plugged" into some sort of circuit board. This board may be of many different types, from one of your own design, to one purchased from Parallax, or even a circuit board from another vendor. Into what sort of board is your Stamp connected?
2. Which Stamp are you using? The expected answer would be something like this -
BS-1, BS-2, BS-2SX, BS-2P40, BS-2PX (not all PBASIC Stamps have been listed).
3. How hot is "hot"? The answer we're looking for is something like the following -
a. Warm to the touch.
b. Warm enough for me to think there is a problem.
c. Hot enough that I feel that I might burn my finger if I keep it on the regulator.
d. So hot that I burned or nearly burned my finger when I held it on there for a short period of time.
e. So hot I see smoke or heat waves coming from the v-reg chip.
Regulators will get warm to hot, even under ordinary circumstances, and are expected to do so. This is all part of how they regulate the voltage passing through them. So, the problem here is a matter of relativity - how hot is "hot", and that's what I'm trying to determine by this question.
4. Are you sure you have inserted the Stamp properly, if you are using a Parallax Carrier Board? It's often easy to insert the Stamp one set of pins too far left, or too far right, and thus cause voltages to appear on pins that they shouldn't. Also, please check the PBASIC Manual (free download from the Parallax web site) to ensure you have the proper chip orientation. By this I mean that you need to know that Pin 1 is inserted where Pin 1 is supposed to go, and NOT the pin socket that is diagonal to it.
More information, including schematics or pictures would be a big help in assisting you.
Bruce Bates
