photoresistors
hi there-
My goal with this boebot is to use the photo resistors to find a burning candle in the dark.
my problem is: up close, the sensors detect light, but any distance away and it doesn't work.
I hope you don't mind if put below the code i'm using.
can you give me advice?
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Variables ]
' Declare variables for storing measured RC times of the
' left & right photoresistors.
timeLeft VAR Word
timeRight VAR Word
average VAR Word
difference VAR Word
[noparse][[/noparse] Initialization ]
FREQOUT 4, 2000, 3000
[noparse][[/noparse] Main Routine ]
DO
GOSUB Test_Photoresistors
' For mismatched photoresistors, use Appendix F, uncomment and use next line.
' timeLeft = (timeLeft */ 351) + 7 ' Replace 351 and 7 with your own values.
GOSUB Average_And_Difference
GOSUB Navigate
LOOP
END
[noparse][[/noparse] Subroutine - Test_Photoresistors ]
Test_Photoresistors:
HIGH 6 ' Left RC time measurement.
PAUSE 3
RCTIME 6,1,timeLeft
HIGH 3 ' Right RC time measurement.
PAUSE 3
RCTIME 3,1,timeRight
RETURN
[noparse][[/noparse] Subroutines ]
Average_And_Difference:
average = timeRight + timeLeft / 2
difference = average / 6
RETURN
Navigate:
' Shadow significantly stronger on left detector, turn right.
IF (timeLeft > timeRight + difference) THEN
PULSOUT 13, 850
PULSOUT 12, 850
' Shadow significantly stronger on right detector, turn left.
ELSEIF (timeRight > timeLeft + difference) THEN
PULSOUT 13, 650
PULSOUT 12, 650
ELSE
' Shadows in same neighborhood of intensity on both detectors.
PULSOUT 13, 850
PULSOUT 12, 650
ENDIF
PAUSE 10
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
timeLeft VAR Word
timeRight VAR Word
average VAR Word
difference VAR Word
DO
GOSUB Navigate
LOOP
END
PAUSE 3
RCTIME 6,1,timeLeft
PAUSE 3
RETURN
RETURN
Navigate:
PULSOUT 13, 850
PULSOUT 12, 850
PULSOUT 13, 650
PULSOUT 12, 650
ELSE
PULSOUT 13, 850
PULSOUT 12, 650
ENDIF
PAUSE 10
RETURN
- Use DEBUG commands to display what the photoresistors sense in the Debug Terminal.
- Datalog a session and then display it in the Debug Terminal later.
Robotics with the Boe-Bot has a DEBUG examples, so all you would need if you are using this approach is a way of having a laptop or PC close enough to the candle course to display the messages. Alternately, you can datalog a session and display the results later. This is presented in Smart Sensors and Applications, Applied Robotics with the Boe-Bot, and Applied Sensors. You can download the full PDF of any of these texts from www.parallax.com.
Andy Lindsay
Education Department
Andy Lindsay
