sensor PING Parallax. Which Power supply do I use?
I have the sensor PING from Parallax working with Arduino. When it is using the 5V power from computer USB it works perfectly, but when I plug a power supply 5V 800 mA, the sensor doesnt work. in the datasheet of PING they say that it uses Supply Current – 30 mA typ; 35 mA max.
the arduino and the leds are working fine with the power supply I have here, only the sensor is not working.
Do you have any idea of what power supply I should get to function everything toghter?
I am using 24 red bright leds 5mm measuring the distance with Ping through light intensity. just that.
Thanks for helping!
anaisa
Thanks for helping!
anaisa
the power supply is working with the arduino and the leds fine. but it is not turning on only the sensor...
It works separetely, arduino and leds...
Do you thing i should try a power supply with low mA?
because in the PING datasheet it says that the max is 35 mA...
Do you thing the power supply has too power?
It works fine when using the USB from computer...
strange....
If you did not understand it, please let me know.
i change the voltage to 6 V !
thanks so much for your help!
ana
