Assembly CALL strange behaviour
RankLoop
add RankCounter, #1
mov testloopcounter, RankCounter
call #testloop
cmp RankCounter, #16 wc,wz, nr
if_a jmp #MainLoop 'If greater than 16 jump to main loop
mov NoteCounter, #0
mov HUB_KeyAddrPtr, HUB_RAM_StartAddr 'Address in Main Ram for HUB access
mov tmpKBImage_W1, #0 'Clear the 3 temporary keyboard image words
mov tmpKBImage_W2, #0
mov tmpKBImage_W3, #0
call #GetStopBytes 'Get 2 Stop bytes for this rank
NextNote
add NoteCounter, #1
cmp Notecounter, #61 wc,wz, nr
if_a jmp #RankLoop 'If > 61 then done with this rank go to next rank
call #GetKeyByte 'Get next note image from keyboard
cmp tmpNote,#0 wz
if_z jmp #NextNote 'Value = 0 no need to process get next byte
call #ProcessByte 'Note value not zero process it
jmp #NextNote
GetKeyByte
rdbyte tmpNote,HUB_KeyAddrPtr wz 'Get next note data from HUB
add HUB_KeyAddrPtr, #1 'Increment HUB address pointer
add NoteCounter, #1 'Increment Note Counter
GetKeyByte_Ret
GetStopBytes
add StopCounter, #1
rdbyte tmpStopByte_1,HUB_StopAddrPtr wz
add HUB_StopAddrPtr, #1
add StopCounter, #1
rdbyte tmpStopByte_2, HUB_StopAddrPtr wz
GetStopBytes_Ret
'!!!!!!!!!!!!! PROBLEM SEEMS TO BE BELOW!!!!!!!!!!!!!!
ProcessByte 'For each Keyboard note, check stop words to see if bits must be set
{cmp tmpStopByte_1, #0 wz
if_z jmp #Skip_1
cmp tmpStopByte_2, #0 wz
if_z jmp #Skip_1
nop}
'mov tmp, #1
{mov testloopcounter, RankCounter
call #testloop}
Skip_1 'nop
ProcessByte_Ret
jmp #mainloop
The code {snip} above works fine until I place any active code in the "ProcessByte" routine. I have a test loop which flashes an LED X number of times depending upon testloopcounter.
This ProcessByte routine is called 7 lines below the "NextNote" label and the strange thing is even if that "CALL" is remarked out, if any code is contained in ProcessByte, the program immediately jumps to "MainLoop" {not shown}. I have even tried "NOP's". If I remark out all code but leave the labels, the routine is called, returns and the processing is as expected.
The code is obviously underdevelopment but worked as espected until I added the ProcessByte routine.
If I just do a JMP #ProcessByte, and replace the ProcessByte_Ret with a JMP #NextNote it also works fine. I can leave this with the jumps but I have a feeling I will trip over this again.
I believe the code shown should only be doing 1 CALL at a time and no Called routine has JMPs out of their respective routines.
Code size seems to be fine and I do have a FIT statement at the bottom.
It appears that the code is just blowing by the ProcessByte_Ret label and hitting the JMP #MainLoop which I am not expecting it to do.
Any thoughts?
Shouldn't there be an actual RET instruction after GetStopBytes_Ret ? Currently a call to GetStopBytes stomps on the first instruction of ProcessByte.
The same for GetKeyByte_Ret.
Added : Like what Ale said, who seems to be a faster typist or quicker analyst
Post Edited (hippy) : 12/12/2007 3:20:31 PM GMT
I missed the RET for both previous called routines yet the code SEEMED to work right but bit me on the 3rd call.
Thank guys!
The default should be locals, but you have to add ":". 8-/
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
