the gripper kit — Parallax Forums
the gripper kit
JulezJulez Posts: 2
edited 2007-12-21 18:20 in Robotics
has anyone had this problem with the gripper kit?
it doesn't want to hold things while its walking
if you had this problem and found a solution can you please tell me
thanks
  • Steve JoblinSteve Joblin Posts: 784
    edited 2007-12-12 13:47
    how heavy is the object you are trying to hold? what shape is the object?
  • dandreaedandreae Posts: 1,375
    edited 2007-12-12 17:34
    Does your Gripper stay closed if you do not have an object between the paddles?· It maybe that your code needs to be modified or that your servo horn needs to be adjusted.
    Dave
    Dave Andreae
    Parallax Tech Support·
  • Joe FishbackJoe Fishback Posts: 99
    edited 2007-12-14 01:25
    Servos need to be refreshed with pulses. You can not just send pulses to the gripper servo and have it stay closed. The new Parallax ServoPal works great doing this refreshing. Send one set of pulses and the ServoPal will continue to send pulses to the servo while your main program does other things. I have tried the ServoPal in different applications using servos. The ServoPal does a great job with both standard servos and with continuous rotation servos.
    The gripper uses a spring in conjuction with a 4 bar linkage to make it close·and lift. The spring is what that is really providing the gripping presure. Therefore sometimes you can lift a object but it slip down out of the gripper. To lift a Coke can I put small lips on the bottoms of side grippers. This lip fits under the Coke can, cutting down on slipage.
    ······ Joe Fishback
    -Robots are my friends-
    2816 x 2112 - 2M
    2816 x 2112 - 1M
  • XNORXNOR Posts: 74
    Joe Fishback said...
    How did you make those gripper pads?
    I can see you screwed them onto the Parallax
    gripper kit, but I don't recognize where those
    pads could have come from.
    I would also be interested in seeing more pictures of
    your Boe-Bot. It looks like you've added some more stuff,
    but it's hard to tell from the pictures of your gripper.
    I'm always curious to see how other people have
    modified their Boe-Bot.
    Thanks!
