PropBus System by R.T Nollet — Parallax Forums
QuattroRS4QuattroRS4 Posts: 916
edited 2007-12-13 01:40 in Propeller 1
Hi Folks,
I just received a PropBus System by R.T Nollet a.k.a 'OZStamp' ..
It is very well laid out -
PropBus MotherBoard
DIP Eeprom,crystal,cap. and two pullup resistors are located under the DIP socketed propeller.
Seperate GND-3.3v and GND-5.0v headers.
Seperate 5v and 3.3v LED's
Diode in series·with Supply header to prevent reverse polarity.
Extremely well ground planed (All unused area on top side of P.C.B)
Generously sized supply tracks - (GND,3.3v and 5.0v)
2 Generously sized heatsinks for regulators.
3 x 10way I/O headers.
Onboard Video and PropPlug headers.
Seperate I2C bus header 6-way (INT,SDA,SCL,0V,5V and 3.3V).
Propeller Pin no.'s labelled on top layer silkscreen.
Kit contents
* 1 off PropBus motherboard
* 3 off Combination in and output boards with indicator + dipswitches
* 1 off Vero board with ribbon connector + other connectors to be able to connected to mother board neatly
* 4 off Ribbon cable to solderless breadboard adapter PCB’s with components
* 1 off Serial port connector to solderless breadboard dip adapter
* 1 off SMD component 8 SOIC adapter PCB for surface mounts components
··· ( allows mounting to solderless breadboard with header pins)
a very nice kit indeed ... well worth having in the toolbox ! - well done Ron..
read more about it here -The Propbus
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 12/11/2007 8:09:52 PM GMT
  • AleAle Posts: 2,363
    edited 2007-12-11 20:37
    *** Werbung ***
  • QuattroRS4QuattroRS4 Posts: 916
    edited 2007-12-11 20:51
    Ale,
    What's that ?
    EDIT: - Ok
    edited 2007-12-11 21:11
    Of course not, it is supposed to be joke, that is why it is just one word, and not in English smile.gif. There were other descriptions of boards here already. I also looked into Oz's boards and was wandering how they were smile.gif
    edited 2007-12-11 21:18
    Ale ... that's great news .. Phew I couldn't believe it there for a second (actually longer) ... blush.gif
    not great at the one word jokes ... especially when that one word is in a different language !
    John
    Post Edited (QuattroRS4) : 12/11/2007 9:33:55 PM GMT
    edited 2007-12-11 22:20
    Hello, It looks like a nice board for the Propeller. I didn't see anywhere on the site or in the docs what the actual pin layout for the 10-pin connectors are. That is something that would help for anyone who wants to use that board. Is it posted somewhere?
    Robert
  • RaymanRayman Posts: 16,224
    edited 2007-12-11 23:14
    That sounds good. I'm thinking about doing my own board design soon... Main things I'd add are:
    SD card reader
    DS1307+ Real time clock
    ENC28J60 for ethernet (assuming I can figure out how to use it one day...)
    I think I like the idea of using the DIP40 Prop, so it can be easily replaced...
    Think I'll also use a DB9 serial connection to program the Prop. USB to serial adapeters are pretty cheap...
  • OzStampOzStamp Posts: 377
    edited 2007-12-11 23:42
    Hi·
    Attached the pdf for the layout of the IDC headers on the Prop Motherboard
    Rayman.. why not make an ·adapter board(s) to my platform.??
    I will send you a empty panel so you can get it going..
    Email me and give me details so we can discuss further if needed.
    I have the same idea of adding those type of modules.. and more.
    Working on a 3 channel high speed encoder system using the motherboard as the main CPU card.
    Thats why we copper poured it .. it is not a toy board really..
    Aimed at educational and pro market.. all I/O (handyI/O blks pcb's)·are protected against damage ..
    Cheers
    Ron Nollet· Mel OZ
    Post Edited (OzStamp) : 12/11/2007 11:56:37 PM GMT
    edited 2007-12-12 00:46
    I'm probably just dreaming (about making my own board)...
    edited 2007-12-12 00:55
    Hi Rayman.
    We call them "Gunners here" gunna do that... gunna this ..
    As the Nike people say... JUST DO IT...
    cheers
    Ron Mel OZ
    edited 2007-12-12 06:14
    I want to have some working soft before I do any more pcbs... I already have some without (that much) soft (not propeller related).
    Decided to run it as a test in an industrial environment ... no problems ..Have to say regs run pretty cool ...fairly flogging it at the mo . It is a great job IMO...
    JT
    Post Edited (QuattroRS4) : 12/13/2007 1:51:43 AM GMT
