DAT variable alignment
Ok, I have 8 bytes, and 30 longs I need right next to each other in memory. I would like to keep each declared as byte/long respectively so that array access doesn't need to be typecast every time I access them. IE: If I declared the 8 bytes as 2 longs, I would then have to access the bytes like: byte[noparse][[/noparse]foo] for the second byte. Doing this in the Var area is hard due to the rearrangement of variables when compiled. So I've moved it all to the Dat section. Now, my next problem, is if the bytes aren't long aligned, then padding -could- get in the way. Sooooo.... I've come up with this idea, and it seems to work, but I'm posting to get some conformation. I would hate to have a problem later with this as it could be hard to debug. This is what I've got:
Now if I'm right, that should always result in the 'name' being aligned and -next to- the 'stuff'. While still allowing them to be referenced as bytes, and longs respectively.
Does that make sense to anyone else?, and am I correct?
DAT 'Data alignme long name byte " TEMP ",0 stuff long 0[noparse][[/noparse] 30 ]
is not well described neither in the Manual nor in the Errata..
I know it "works" what you do, but I have no reference to support that.
The section on DAT in the manual covers the alignment issue.
Help to build the Propeller wiki - propeller.wikispaces.com
Play Defender - Propeller version of the classic game
Prop Room Robotics - my web store for Roomba spare parts in the UK
I think I will be not the only one who wasn't aware that
is a valid and useful expression....
Well, I'm glad I asked, thanks for the help everyone. I'm going to go simplify that area of my code now
EDIT: Ohhh and deSilva, unless I'm mistaken 'label BYTE LONG $01020304' isn't a useful expression. -label- would be byte-aligned and long-sized. Longs are always byte aligned. [noparse];)[/noparse]
EDIT2: Ok... I'm missing something I think. 'label LONG BYTE "Blah"' Doesn't work. It seems that the 'size override' must be larger than the alignment. I don't quite see the point in that... I guess you could have short-aligned longs, but other than that... what's the point? byte aligned longs/words doesn't make sense, aren't they always byte aligned? I need Long aligned Bytes, but that doesn't seem to work...
I think my previous code works... but this would have been more elegant. Can anyone point out what I'm missing?
EDIT3: Ok (I say that alot...) If I declared a long as byte-aligned, then it wouldn't pad the previous value to get to a long-aligned value... that makes sense. But, since I can't do a long-aligned byte, I still have to use my original code above... right? Sorry if I seem a bit off, trying to figure this out....
Post Edited (James Newman) : 12/12/2007 12:03:41 AM GMT
Consider this, which happens to start at $0400 in memory:
DAT
label1 long 1
label2 byte 2
label3 long 3
That produces the following sequence of bytes in memory:
$0400: 01 00 00 00 'long aligned long
$0404: 02 00 00 00 'byte plus three bytes of padding
$0408: 03 00 00 00 'long aligned long
Suppose instead you do
DAT
label1 long 1
label2 byte 2
label2 byte long 3
Then you'd get:
$0404: 02 'byte
$0405: 03 00 00 00 'byte aligned long
See how how second long doesn't have to start on a 4 byte boundary because it is byte aligned rather than long aligned.
It's worse than that. Neither Spin nor the assembler will let you read longs that are not long aligned or words that are not word aligned. You'd have to read them as bytes, and combine them together to reconstitute a long or word yourself.
So unless you have a very good reason to do so, you really don't want to go there. (A good reason being a pre-existing data format that you need to follow for some reason).
The best thing to do is to group all longs together, all words together, and all bytes together, and then not worry about the maximum possible 3 bytes per program you've wasted.
