BS2px
Math
I would like to refer to [url=mailto:NV@V]NV[/url] Column #83, program simple GPS.BSP.
When using the· program on a· BS2p40 in a P40 Demo Board, the program shows the data in the debug window.
When using, however a BS2px in a board of education , the debug window doesn't show any data; although I set the baudrate in the debug window on 19200, as requested.
Any idea what could be wrong?
Many thanks in advance.
Math
Math
Sorry,·I should, indeed·have set the baudrate on 17.197 (8 bit, no parity, inverted ) for a BS2px24 i.l.o. keeping it on 16848 for a BS2p40.(as in the column)
Many thanks.
Math
Since this Thread concerns the BS2px and the BS2p40, I thought I should write here.
I just purchased (and received) some Processor chips for the BS2px and BS2p40. The chips I received are exactly the same.
Do these two models use the same processors? Is it just the resonator speed that differenciates these two?
I am about to solder these chips onto the PCB.
When I purchased these chips the number on the photo said: SX48BD/TQ for the p40 and SX48BD/TQ-G .
All eight chips that I received (ordered 4 of each for the px and p40) have the SX48BD/TQ-G marking on the chip.
Looking forward to your reply.
David
Yes, the resonator speeds are different on different models and the firmware is programmed with the correct settings for the given model and the resonator and resistor used. I hope this helps.
Dave
Thanks!
Thanks for the quick reply! However, "Ouch", The chips came in a cute little brown box, the ICs just sitting on top of the anti-static foam. Looking at the box, I see there are some dimly scribbled numbers on the outside of the box. In retrospect this probably is supposed to indicated the respective location inside the box, However, the ICs were slightly jumbled when I opened the box and I already removed them from the box, to put with the rest of the components, thus I have no clue how to distinguish the chips....
Any ideas about what to do?
I am considering soldering on a TQFP socket (a royal pain) so I can swap ICs until I discover which is which. I've done this before with a 0.5mm pitch TSOP 48 FLASH chip, and it worked like a charm.
Any extra insght would be appreciated.
THanks,
David
If you were stateside I woul suggest sending them in to us to reprogram and send back to you more clearly marked and separated. At this point, based on your location if you have the socket you could connect the chip to an SX-Key (4 connections) and ID the chip from there. This would tell you which is which.
Jim
Dave
I'm good for now Dave.
I know Parallax will be true to their word.
Jim
