Programming Parallax continuous rotation servos??
I'm having trouble programmimg these continuous rotation servos. Can anybody help me with something like - "rotate clockwise for a period, stop for a period, rotate ccwise, stop - etc. I want to animate a piece of kinetic art in a more or less random way.
- Stephen
ServoPin CON 2
ServoPos VAR WORD
MAIN:
· ServoPos = 500·· ' 500 * 2 uSec is rotate full one way
· FOR I = 1 to 100· ' 100 * 20 mSec == 2 seconds
··· GOSUB RotateServo
· NEXT
· ServoPos = 750· ' 'Stop'·value is 1.5 mSec, or 2 uS * 750
· GOSUB RotateServo
· PAUSE 1500· ' 1.5 seconds
· ServoPos = 1000· ' 1000 * 2 uSec is rotate full the other way
· NEXT
· ServoPos = 750· ' Send 'stop' again
· GOSUB RotateServo
· Pause 500· ' Wait 1/2 second this time...
· GOTO MAIN
RotateServo:
· PULSOUT ServoPin, ServoPos
· PAUSE 20
· RETURN
Post Edited (allanlane5) : 12/10/2007 6:55:32 PM GMT
ServoPin CON 2
ServoPos VAR WORD
I VAR WORD 'had to add this'
MAIN:
ServoPos = 755 ' 500 * 2 uSec is rotate full one way
FOR I = 1 TO 100 ' 100 * 20 mSec == 2 seconds
GOSUB RotateServo
NEXT
ServoPos = 750 ' 'Stop' value is 1.5 mSec, or 2 uS * 750
GOSUB RotateServo
PAUSE 1500 ' 1.5 seconds
ServoPos = 1000 ' 1000 * 2 uSec is rotate full the other way
GOSUB RotateServo
NEXT
ServoPos = 750 ' Send 'stop' again
GOSUB RotateServo
PAUSE 500 ' Wait 1/2 second this time...
GOTO MAIN
RotateServo:
PULSOUT 14, ServoPos
PAUSE 20
RETURN
Or in this simpler program
counter VAR WORD
DEBUG "ccwuse 10",CR
FOR counter = 1 TO 10
PULSOUT 14, 800
PAUSE 200
NEXT
PAUSE 10000
DEBUG "cwise 2", CR
PULSOUT 14, 700
PAUSE 200
NEXT
PAUSE 10000
DEBUG"ctr", CR
PULSOUT 14, 750
PAUSE 200
NEXT
DEBUG "fin", CR
END
Then, the above programs assume you're using a BS2 'plain'. If you don't HAVE a BS2 'plain', then the "PULSOUT" numbers must be adjusted for the 'flavor' of BS2 you DO have. Otherwise, you won't get the right pulse widths for the servo.
THEN, a servo pulls about 100 mA to 500 mA. You can't do this with a 9-volt battery -- they 'brown out' and your BS2 resets. You MUST use 4 AA batteries or a wall-wart power supply or equivalent if you're going to drive a servo.
I'm using a BS2e and have determined the appropriate pulswidths as above. So thay are OK and do as I expect.
Ah - Do you mean DURING the running of the program the battery browns out - because the battery is OK as tested and runs the beginning of the program again and again? On the oher hand a 9 V battery runs two discontinuous servos perfectly well??
The only thing that appears not to work is getting out of and past the first FOR- NEXT loop.
Many thanks
Post Edited (Peter Rand) : 12/11/2007 2:46:08 PM GMT
So yes, a perfectly good 9-volt 'transistor' style battery WILL 'brown out' when the Servo starts up.
