DC Motor speed control
Hello,
I am looking to build a DC motor speed control.
The motor is 12volt, Permanent Magnet. The spec sheet shows just under 6 amps under load, more amperage needed for start up I'm sure. No number is published for the locked rotor amperage.
I would like to control this with a SX-48 using the TIMER function. I'd like to use the adjustable PWM of this feature to control the speed of the motor.
Can I do·this with a few MOSFETS in parallel?
I've thought of·one logic level transistor controlled directly from the SX pin to control 2-3 MOSFETS in parallel to share the amperage of the motor?
I understand Parallax has a HB-25 motor controller,·but would like to avoid spending $50. I figure·I may be able to do this for less than $10 as described above.
Any comments, ideas, suggestions?
I did a search on motor control and didn't find anything directly related to this.
Alex
Alex
A single mosfet can be used as long as you don't exceed its power rating. Be carefull about handling the mosfets, they can be easily damaged by ESD. It's also a good idea to put a heavy duty diode in reverse bias across the load so you circuit isn't zapped by the motor's inductive kick.
Try searching for PWM, instead of motor control; there are a number of circuits on the web.
Check out this link if you haven't already done so. It's on this web site as a down-loadable PDF file of the book "Exploring the SX Microcontroller w/assembly and BASIC programming"
http://www.parallax.com/Store/Books/SX/tabid/169/CategoryID/43/List/0/Level/a/ProductID/414/Default.aspx?SortField=ProductName%2cProductName
It has some info along the same lines as what you want to do with the SX.
It's FREE, which puts it into my price range
Craig
I have a duel boot of Ubuntu Linux and Windows Vista. Vista, because it came with the PC, Ubuntu because I like software that works.
"If Python is executable pseudo code, then Perl is executable line noise."
"Failure is not an option -- it comes bundled with Windows."
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Windows for Solitaire
Post Edited (Phil Pilgrim (PhiPi)) : 12/16/2007 2:52:49 AM GMT
On my motor control boards, I like to put a line down the middle. To the left of this line, is the logic side. To the right of the line is the power switching stuff (mainly the FETs). The only thing that is allowed to cross this line and connect the two sides are the optos, which sit directly on top of the line. Therefore, everything (even ground) is seperate, therefore strictly seperateing the electrical noise from anything that could be messed up by it.
regards,
Craig
PS. Phil, I think the PDF you linked to is dead. It crashed both browsers I tried to open it with.
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Post Edited (crgwbr) : 12/18/2007 5:31:42 PM GMT
I'll look into the optocouplers a bit more as they seem to be a popular choice for many.
My one question is that since the SX pin may have trouble turning on the gate of a large MOSFET, couldn't I put a transistor in between? What I mean is having the pin turn on a transistor which would better carry the current of turning on the MOSFET's gate? And using 2, maybe 3 MOSFETS to handle the current?
Alex
If at first you don't succeed, then skydiving is not for you.
Craig
P.S. Don't forget to put a pull-down resistor in the gate. This is very important, as the FET will stay on as long as the Gate (acting like a capacitor) stays powered. The pull-down will drain the power from the gate after you stop supplying power.
My system: 1.6 GHz AMD Turion64 X2, 4GB DDR2, 256MB ATI Radeon Graphics card, 15.4" Widescreen HD Screen
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
system.windows.codeslinger.googlepages.com/motorcontroller2
I wish that I had known before about that optocoupler that can drive MOSFET's - thanks Phil! I would definitely use an optocoupler next time; it is nearly impossible to filter out all of the spike voltage from the motor switching. I never did get rid of all of it. You can even get spikes back-driven through your gate driver, and I had ground bounce between boards. If I had used an opto to drive the MOSFETs, it would have been much easier to keep the spikes out.
Also, note that there is an error in my schematic or at least my description of the schematic: I ended up having to use a much bigger filter than I described across the motor; a huge bank of medium-sized capacitors, and 100 watt's worth of power resistors in series with the capacitor bank, to absorb the spikes coming off the motor switching. It probably wastes a lot of power that way but it just goes to show how energetic the spikes coming off the motor can be if you don't tune your MOSFET switching right (as mine is not). Also I did not use Schottky diodes, I used regular ones, and perhaps the slow switching speed of the regular diodes makes them insufficient to absorb switching spikes.
