Checking the input register and the If command question — Parallax Forums
JMLStamp2pJMLStamp2p Posts: 259
edited 2007-12-10 18:37 in Propeller 1
Hello, I want to·monitor input register "A" and jump to Johns sub-routine when it has ack. a logical high or 3.6V on Pin "21". Could someone please look at my code in the CheckPin method below and make comments
on where I am·coding wrong.
CON
· _CLKMODE····· = XTAL1 + PLL8X·······················
· _XINFREQ····· = 8_000_000
· dSlow········ = 50
· dFast········ = 20
OBJ
· OLED· : "uOLED-96-Prop_V4"
· DELAY : "Clock"
· DATA : "FullDuplexSerial"
VAR
· long Stack [noparse][[/noparse]9]
· byte Byte_Recieved
· byte Temp
PUB MAIN
· DELAY.Init(8_000_000)
· OLED.InitOLED
· OLED.CLS
· Transmit
PUB Transmit
· data.start(21,20,0,9600)····· 'Set up Serial Commands
· DELAY.PauseSec(7)············ 'Wait for OLED to stabalize
· data.tx($55)··················· · 'Send Auto Baud Command
· DELAY.PauseSec(3)············ 'Wait for at least 1 sec.after Auto Baud before sending Commands
· CheckPin·························· 'Goto the CheckPin method
PUB CheckPin
· Temp:= INA[noparse][[/noparse]21]··············· 'Wait for Pin "21" to go High
· If Temp == 1··················· 'If Pin 21 is High·goto Johns
··· Johns
· If Not CheckPin················ 'If not re-check Pin "21"
PUB Johns
· data.tx($40)················· 'Pic. Commands sent to the OLED-160
· data.tx($49)
· data.tx($00)
· data.tx($00)
· data.tx($80)
· data.tx($80)
· data.tx($10)
· data.tx($00)
· data.tx($10)·
· data.tx($00)
· data.tx($0B)
· data.tx($00)
· data.tx($00)
· data.tx($00)
· data.tx($00)
· waitAck······················ 'Wait 3 seconds for Ack. after Command sequence before continuing
·· DELAY.PauseSec(10)
·· OLED.CLS
PRI waitAck·······················
·· waitcnt(3_000_000+cnt)····················
  • rjo_rjo_ Posts: 1,825
    edited 2007-12-09 06:32
    You should explicitly set dira to zero before your ina.
    if not temp == 1
    you could also use
    repeat while temp <> 1
    dojohns (same indent as your repeat)
    Rich
    edited 2007-12-09 06:34
    can't post edit yet...in the last line above I renamed your "Johns"... a little tired. Sorry.
  • hippyhippy Posts: 1,981
    edited 2007-12-09 10:56
    PUB CheckPin
      Temp:= INA[noparse][[/noparse]21]                'Wait for Pin "21" to go High
      If Temp == 1                    'If Pin 21 is High goto Johns
        Johns
      If Not CheckPin                 'If not re-check Pin "21"
    A nasty bit of recursion there, as well as probably not doing what's intended. Perhaps you mean ...
    PUB CheckPin
      repeat until INA[noparse][[/noparse]21] <> 0
      Johns
  • deSilvadeSilva Posts: 2,967
    edited 2007-12-09 13:53
    @JMLStamp2p
    You have some misconceptions
    - with the use of IF and ELSE
    - with the use of routines
    What you do is possible in some high end functional languages which recognize tail recursion and stepwise refinement resolution, but the garden variety of languages work differently. Check some other person's programs to get the idea.
    Your program could read
      _CLKMODE      = XTAL1 + PLL8X
      _XINFREQ      = 8_000_000
    OBJ
      OLED  : "uOLED-96-Prop_V4"
      DELAY : "Clock"
    [b]PUB main[/b]
      OLED.InitOLED
      OLED.CLS
      ' Transmit
      DATA.start(21,20,0,9600)     'Set up Serial Commands
      DELAY.PauseSec(7)             'Wait for OLED to stabalize
      DATA.tx($55)                      'Send Auto Baud Command
      DELAY.PauseSec(3)             'Wait for at least 1 sec.after Auto Baud before sending Commands
      UNTIL INA[noparse][[/noparse]21]                   'Wait for Pin "21" to go High
      ' no loop body for simple wait loop
      ' WAITPEQ(|<21, |<21) would do the same
      data.tx($40)                  'Pic. Commands sent to the OLED-160
      data.tx($49)
      data.tx($00)
      waitAck                       'Wait 3 seconds for Ack. after Command sequence before continuing
      DELAY.PauseSec(10)
      OLED.CLS
    'end of main; COG stops here
    [b]PRI waitAck[/b]
    Note that it is bad practice to use 3_000_000 (better: CLKFREQ*3/5), or mixing WAITCNT and DELAY...
    Your program could also go:
    OBJ
      DELAY : "Clock"
    PUB main
      OLED.InitOLED
      OLED.CLS
      Transmit
      CheckPin                           'Goto the CheckPin method
      Johns
    PUB Transmit
      data.start(21,20,0,9600)      'Set up Serial Commands
      data.tx($55)                      'Send Auto Baud Command
    PUB CheckPin
    PUB Johns
      data.tx($00)
      DELAY.PauseSec(10)
      OLED.CLS
    PRI waitAck
  • JMLStamp2pJMLStamp2p Posts: 259
    Thanks guys for the help, it is greatly appreciated.
    JMLStamp2p
