ASAP, trying to control a RC???
Hi everyone, I need help on this, for Monday,
I have a RC car, and was able to break into the connection and control how fast the car go, by doing this:
·FOR i = 1 TO 1000
··· HIGH 0
··· PAUSE 10
··· LOW 0
··· PAUSE 25
·NEXT
My only problem is that i want to the car to go this speed only when it receives a signal from the Transmitter, if there is no transmitter, go full speed·, so far i have this:
DO
LOW 0
SERIN 7, 16468, [noparse][[/noparse]WAIT("!"), x.HIGHBYTE, x.LOWBYTE ]
HIGH 0
DEBUG ? x
IF (x = 25 )· THEN
FOR i = 1 TO 1000
··· HIGH 0
··· PAUSE 10
··· LOW 0
··· PAUSE 25
·NEXT
ELSE
FOR i = 1 TO 1000
··· HIGH 0
··· PAUSE 100
··· LOW 0
··· PAUSE·5
·NEXT
ENDIF
LOOP
Thanks in advance!!!
·FOR i = 1 TO 1000
··· HIGH 0
··· PAUSE 10
··· LOW 0
··· PAUSE 25
·NEXT
DO
LOW 0
HIGH 0
DEBUG ? x
IF (x = 25 )· THEN
FOR i = 1 TO 1000
··· HIGH 0
··· PAUSE 10
··· LOW 0
··· PAUSE 25
·NEXT
ELSE
FOR i = 1 TO 1000
··· HIGH 0
··· PAUSE 100
··· LOW 0
··· PAUSE·5
·NEXT
ENDIF
LOOP
FOR i = 1 TO 1000
··· HIGH 0
··· PAUSE 100
··· LOW 0
··· PAUSE·5
·NEXT
and the custom defined speed is...
·FOR i = 1 TO 1000
··· HIGH 0
··· PAUSE 10
··· LOW 0
··· PAUSE 25
·NEXT
I·think i see·the solution, try this code....
add x = 0 after ENDIF
The problem was if no transmission came x will still be 25 from the last transmission, so you need to set it to 0 before using it agian.
