How to HIGH multi pins at once? And communication error 240 or 40 questions
In PBasic I do this to fire multi pins at once on· BS2:
DIRL = %11111111
Main:
DO
· GOSUB a
· PAUSE 500
· GOSUB b
· PAUSE 500
· GOSUB c
· PAUSE 500
LOOP
A:
·OUTL = %11111110
·OUTL = %11111100
·OUTL = %11111000
·OUTL = %111110000
RTURN
ETC..
How to do this·with SX/B (from RC.0....RC.7)?
Second question is that when I connect SX Tech to the Notebook· through Usb to Serial adapter (SX Key) after Erasing message, start programming and after few seconds appear new message with warning - communication error 240 0r 40
On the old notebook PIII with serial comm I haven't this problem. Anybody knows why?
THANKS!
Think deep......Dive shallow !!!
DIRL = %11111111
Main:
DO
· GOSUB a
· PAUSE 500
· GOSUB b
· PAUSE 500
· GOSUB c
· PAUSE 500
LOOP
A:
·OUTL = %11111110
·OUTL = %11111100
·OUTL = %11111000
·OUTL = %111110000
RTURN
ETC..
THANKS!
· HIGH RC
Bean
www.iElectronicDesigns.com
Post Edited (Bean (Hitt Consulting)) : 12/8/2007 7:52:46 PM GMT
but what I want is something like
HIGH RC.0··LOW RC.1 HIGH RC.2,
not to HIGH all pins or LOW all pins. Can you help me?
Like "RC = %10101010" if the all the pins are not set for output then use "OUTPUT RC" first.
P.S. You can also use "HIGH RC" or "LOW RC" to set the pins to output and set the state (high or low).
Bean
That is wery simply, but I can't find it in manual. Do you now whay recive error message during programming SX chip.
Is the computer XP, Vista, other ?
There are some setting in the Device Manager that you can change that may fix it, I don't remember what they are off-hand. Maybe someone else can chime in if they know.
Bean
Thank you
