*Solved*: Is an assignment (SomeVar:= someValue) atomic? It *IS*
Hi!
[noparse][[/noparse]Edit]
Have written a test program. One Updater in SPIN, and an Observer in ASM. And I cant observe what I suspected.
So the error is somewhere else (despite having chased it for a day).
I leave my the question JFTR
[noparse][[/noparse]/Edit]
Admittedly, this question sounds *quite* strange. But I'll describe the problem:
I have one cog running some SPIN-code that is updating a global var (I call it triggerPattern). This global var is repeatedly fetched from ASM (via rdlong) and used for generating some timed pulses on a pin.
Now if I let repeatedly update the var "triggerPattern" from SPIN, I do have jitter on the output. If I remove the update and only write the var once with some value, the jitter is gone. Ah!, you'll say, the value you write isn't constant. It is, I changed the code to repeatedly write the *same* value.
Now does that make sense?
I'd expect that a
does do a wrlong deep down inside the SPIN interpreter. Without any side-effects.
If that makes a difference, "triggerPattern" is in fact an array.
Any insights?
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Post Edited (Nick Mueller) : 12/8/2007 4:07:41 PM GMT
I'd expect that a
triggerPattern:= someLocalVar
Any insights?
Nick
YADRO
You might learn something from that value... It will be most likely "zero"..
The internal working of the SPIN interpreter is still a secret
However, if you are always writing the same value in the Spin code, unless the hub variable is being cleared by the Spin interpreter before the value required is written it should never change at all.
If the Spin interpreter updates using wrlong and doesn't alter the variable before (re)writing the required value, I'm at a loss to explain the jitter.
You could add a lock around the spin code and your rdlong so the variable is never read while being updated by the spin interpreter. That would help identify whether it was an interaction with the way the interpreter operates or some other issue.
That's exactly what makes me wonder the most.
> You could add a lock around the spin code and your rdlong so the variable is never read while being updated by the spin interpreter. > That would help identify whether it was an interaction with the way the interpreter operates or some other issue.
No time for reading/writing a lock.
I have packed the information that needs to be in-sync/atomic into a single long.
I'll write a testprogram to verify what I can't believe.
Anyhow, the SPIN-code that is updating the global value has to be reqritten in ASM (does it now for testing) and then I won't no longer have that problem. I just stumbled over the problem when I saw the jitter and had no explanation for it.
I'll keep you updated.
Nick
YADRO
You have one cog running Spin that does a "triggerPattern := localVariable". You have another cog running an assembly program that does a RDLONG on the location of triggerPattern. You've setup localVariable so it is a constant value. You see jitter on your signal that implies that there's a timing interaction between the cogs, that somehow triggerPattern changes briefly from what's expected.
The above can't happen as described. WRLONG is indeed atomic, accomplished indivisibly during one hub cycle, and, other than changing the contents of that long, does not affect other cogs. There must be something else going on in your code and we can't tell without the source code to look at.
thanks guys for your time I wasted with my question.
An assignment to long in SPIN *is* atomic (see my edit of the original post).
Albeit, no explanation of my problem. But you can't help me there.
Nick
YADRO
