BOE bot power issue
My robot group is working on a BOE bot project that requires the bot to pick up 8 ping pong balls and dump them into a bin. To do this we are running 3 servos, 4 line following sensors and 1 6v electromagnet that controls the dumping mechanism.
We are having trouble getting power to all of these. Individually, they work, but the robot sputters and stops when we attempt to run the whole system. We've been told that the servos are drawing so much current that there is not enough available for the other systems. To overcome the power limitations , we have attempted to connect multiple 9v batteries in parallel.
This hasn't been successful. We've come up with another battery from an RC car that is 1 amp and 9.6 volts. We have some reservations about using this source. Although we know that it is within the 12 V range of the board, we haven't seen any power ratings for the BOE bot board and we're worried that we could fry the board if we ran an amp through it.
Here's how we're thinking of connecting this battery:
Instead of using the 9V port, we want to splice the new 1 amp battery pack·through the 6 9 VDC port. If we do this, I think we'll have enough current to power everything.
I want to know if anyone here is knowledgable enough of the BOE bot's power capabilities to advise us on this power issue and anything else that may come up as we attempt to fix it. We are working in a 1 week time frame to have this project completed, and although the power issue is the only thing holding us back other issues may come up from fixing the power problem.
are you trying to power the electromagnet from the same source? they can draw a ton of amperage.
you need to look up, calculate or measure the current through each part add them up and supply the required amperage. you could easily add another Power supply go give you more amperage. adding batteries isn't the solution. how ever the more amperage your drawing at once the quicker your going to drain your batteries. hope that helps
ok I'm a little confused when I reread your message. Is the 1 amp battery pack a battery or a battery and power supply.
bottom line add another power supply as required to provide the right amperage. only connect the ground between each power supply.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Post Edited (Dgswaner) : 12/7/2007 11:11:31 PM GMT
electromagnet is similar when activated. It's quite possible that you're getting noise spikes that are causing the Stamp to reset.
The BOE regulators are current limited and will shut themselves down if the current through them goes over roughly 1-1.5A or
if they overheat since they're dissipating the extra voltage (above 5V) times the current through them.
In any event, isolating the high current loads and feeding them from a separate power supply would be helpful. The servo ground (black wire) and control signal (white wire) still need to be connected to the BOE, but the power source (red wire) can go to a source of 5-7 volts. Do not run servos from greater than 7.5V or you will shorten their life and your electromagnet is specified for 6V. Your best
solution is an external 6V battery pack.
If you want to use NiMH cells, a 5 cell battery (like C cells - check their current capacity. A lot of rechargable C cells that are sold are only AA cells in a larger package) would be excellent to feed the servos and electromagnet. The battery's negative terminal has to be connected to the BOE's ground. The BOE itself needs to be powered from a 6V battery as well. Because of the lower drain from just the Stamp and the sensors, you could run this off 4 alkaline cells or 5 NiMH cells (like AA cells).
- Stephen
As for the relay, right now we're using a SPDT relay rated at 5V and 1 amp with a nominal current of 83.9 mA. We also have a 12V, 1 amp relay with a nominal current of 37.5 mA. I've heard that the boe bot's current output is around 22 mA. How would we wire a transistor to one of these to get it to work?
