USB Oscilloscope
Dear Sir,
I'm learning how to measure using oscilloscope, and the Parallax USB osciloscope has become my choice. Now I have a plan to build a DC power supply with a variable voltage from 0 to 12V.·May·I use this oscilloscope to check the·output DC voltage if the current is 10A? I know only the limitation of 20 Vpp maximum input for ch1 and ch2, but how about the limitation of maximum current for both channels? The other thing is, may I check the voltage directly on the transformer to confirm the correct voltage (12V)?
Thanks for your information.
Mike only·
Mike only·
So, what you're really asking is, if you put 12 volts across the o'scope inputs, what's going to happen? And what happens depends on the "input impedance" (aka "input resistance") of the o'scope probes. Which usually is quite high -- 1 MegOhm to 10 MegOhms. 12 volts divided by 10 MegOhms doesn't result in much current.
So yes, if the probes can withstand 20 volts peak-to-peak, they can certainly withstand 12 volts DC.
How about if the power supply (ps)·is running and it's connected to the 12V instrument, which maybe need 10A? May I·still check the output voltage on the ps using USB scope? Because I'm sure that the high current (10A) will flow into the scope's input
Mike only.
If your circuit is pulling 10 amps out of a 12 volt supply, then V/I = R, or 12/10 == 1.2 ohms. Your 12 volt instrument is acting like a 1.2 ohm load. If you now connect a volt-meter, or an o'scope probe, between the 12 volt supply line and ground, you've now created another 'branch' in your circuit. The current in that 'branch' will ONLY depend on the voltage across that branch, and the resistance of THAT BRANCH. In the case of a voltmeter or an o'scope probe, the resistance of the probe is around 10 MegOhms -- so 12 volts / 10e6 Ohms == 1.2e-6 Amps, or 1.2 micro-amperes.
In other words, a voltage probe like a voltmeter or o'scope probe won't see the 10 amps 'flying by' to your 12 volt instrument. It's the voltage limitation (that 20 volts peak-to-peak) that matters, and 12 volts is less than that, so you're ok.
Now, you MUST NOT hang your o'scope probe off of 115 VAC lines. Not because of the current, but because the 115 volt voltage will destroy the probe, because that IS above the 20 volt peak-to-peak limit.
Jeff T.
That has increased my confidence-level on how to use this scope in my other projects
Best Regards,
Mike only
Post Edited (Mike only) : 12/10/2007 4:40:47 AM GMT
regards,
Craig
"... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." -
"If Python is executable pseudocode, then perl is executable line noise."
"The best accelerator available for a Mac is one that causes it to go at 9.81 m/s2."
"My software never has bugs. It just develops random features."
"Windows isn't a virus, viruses do something."
"Programmers are tools for converting caffeine into code."
"Enter any 11-digit prime number to continue."
