standard servo position
I'm curious if there is a simple way to read a servo position? I'm using a standard servo and don't want to worry about it hitting its rotational limit. It could simply go the other direction.
thanks
thanks
Of course, you can always add a position sensor to the shaft of the servo, but that's not really "simple".
The good news is, if you give it a 1 mSec pulse, to a 2 mSec pulse, with 1.5 mSec mid-position, it shouldn't hit its stops.
Yes, there apparently IS a way. Beau Schwabe accomplished this with the Propeller and standard servos and stated "Note: This could also be accomplished with a BS1,BS2, SX, etc.".
http://forums.parallax.com/showthread.php?p=678797
Here is one.
http://www.nubotics.com/products/ww01/index.html
SJW
