Propeller Counters ?
I’m studying the propeller counters documentation.
I’m really new to electronics. I’ve managed to build a simple
Colpitts Harmonic Oscillator with a 5MHz crystal on my breadboard
according to spec.
I plugged it into the FrequencyCounter.spin program on Prop.P7
It seems to be functioning, but it’s displays a 5 digit number (13000 – 15999) which the spin program sayes is in Hz.
My crystal is 5MHz but 13000 is 0.013Hz· Correct ? not 5000000Hz· (5MHz)
Anyway, the reading is bouncing from 12000 – 15999
The sinusoid looks clean on my scopy, but I don’t have a good frequency counter
to double check it with.
Any advise, why is it only displaying 5 digits ?
-Areal
I have a tree growing out of my head, but
what do you expect ? I'm a programmer.
according to spec.
-Areal
5MHz
Wont that kill my propeller ?
Ua... I ran it at 6vdc for about 30-45 seconds before I caught myself [noparse]:([/noparse]
What voltage should I run a 5MHz crystal at ?
-Areal
Post Edited (Areal Person) : 12/5/2007 4:16:01 AM GMT
Also, have you modified the frequency counter program at all? If so, you'll need to post that as well (as attachments).
A 13 kHz signal has a eriod of ~ 77 us and a 15 kHz signal one of 66
Here's the Colpitts circuit I'm using
http://www.radio-electronics.com/info/circuits/transistor_crystal_oscillator/crystal_oscillator.php
I'm powering the oscillator at 6vdc the output signal is going into P7 of the Propeller which is running at 3.3vdc
However, the Crystal will operate at 3vdc also. (But the output number is droping)
Would the Propeller be syncing 6.0vdc ?
Also, does anyone know of a way that I can use the harmonics·of the fundamental frequency (harmonics being 2, 3, 4, etc. times the fundametal, or 3/2, 5/2, etc. being overtones), using some L and C components to lock the circuit into that frequency.
I need to do that, but I'm a greenhorn.
Just give me the general instructions, I can figure out the details of implementation.
I want to split two harmonic levels out from the fundamental frequency so I can implement FSK
What components would I use to get the harmonic frequencies ?
Can I use the Propeller for this ?
Thx
-Areal
Sorry for asking, but do you need a sinuoidal wave or square is good enough ?, because the propeller can generate these signals... square I mean.
A maybe more costly but somehow more controllable will be to use a DDS (AD9835 for instance or 9834)... they provide stable sinus outputs... and are not _that expensive_ 5 € each or so.
Are you sure freqcounter.spin can detect so high frequencies ?... I did not look at it...
