what is pins = lkup & %00111111??
I am writing a BS2 program for traffic light signal,
code is :
' {$STAMP BS2}
' {$PBASIC 2.5}
' pin5 EW/Red
' pin4 EW/yellow
' pin3 EW/green
' pin2 NS/Red
' pin1 NS/yellow
' pin0 NS/green
'Traffic Signal Project
NSgo VAR Byte
NSgo = %0000100000100001
NSyel VAR Byte
NSyel = %0000001000100010
allRed VAR Byte
allRed = %0000000010100100
EWgo VAR Byte
EWgo = %0001000000001100
EWyel VAR Byte
EWyel = %0000001000010100
' === Other Constants ===
day VAR Byte
day = 8
night VAR Byte
night = 4
PushBtn PIN 6
' commented out
'INPUT 6
'NScar VAR Byte
'NScar = IN6
phCell VAR Byte
phCell = 7
'===Variables====
seq VAR Byte
seq = B11
qSecs VAR Byte
qSecs = B10
lkup VAR Byte
lkup = W4
time VAR Byte
time = W4
minTime VAR Byte
minTime = W3
dark VAR Byte
dark = B5
'====Program=====
DIRS = %00111111
again:
GOSUB dayNite
FOR seq = 0 TO 5
LOOKUP seq, [noparse][[/noparse]NSgo, NSyel, allRed, EWgo, EWyel, allRed], lkup 'Get bits..
time = lkup /64
FOR qSecs = 1 TO time
PAUSE 250
IF seq <> 3 OR NScar = 1 THEN continue
IF qSecs > minTime THEN changeLight
continue:
NEXT
changeLight:
NEXT
GOTO again
dayNite:
....some code here...
RETURN
Now, what is pins here :
this is BS2 progams...how do I set pins to that output....any ideas ?
Please help, running out of time,
Hiren Patel
hiren97@yahoo.com
code is :
' {$STAMP BS2}
' {$PBASIC 2.5}
' pin5 EW/Red
' pin4 EW/yellow
' pin3 EW/green
' pin2 NS/Red
' pin1 NS/yellow
' pin0 NS/green
NSgo VAR Byte
NSyel VAR Byte
allRed VAR Byte
EWgo VAR Byte
EWyel VAR Byte
day VAR Byte
day = 8
night VAR Byte
night = 4
PushBtn PIN 6
' commented out
'INPUT 6
'NScar VAR Byte
'NScar = IN6
phCell VAR Byte
phCell = 7
'===Variables====
seq VAR Byte
seq = B11
qSecs VAR Byte
qSecs = B10
lkup VAR Byte
lkup = W4
time VAR Byte
time = W4
minTime VAR Byte
minTime = W3
dark VAR Byte
dark = B5
'====Program=====
DIRS = %00111111
again:
GOSUB dayNite
FOR seq = 0 TO 5
time = lkup /64
PAUSE 250
continue:
NEXT
changeLight:
NEXT
GOTO again
dayNite:
RETURN
Hiren Patel
hiren97@yahoo.com
- Stephen
Look at Table 4.1 and Table 4.2 on pages 82-83 in the Basic Stamp Manual for details. For setting
the pins to output, use OUTL (which uses pins 0-7) and use DIRL instead of DIRS. DIRS will work,
but it's a 16 bit register rather than the 8 bit register on the BS1. Also, as you will see from the
tables, the input and output registers are different.
