low voltage cut-off?
All,
Is there an easy way to make a low voltage cut-off?· I.e. to protect lipo's from over discharge (3v per cell).
I have low drop out reg's with ENable pins - I just cannot find an easy way to drive high or low when the voltage is low.
James
James
Would a thyristor with the gate connected to the TC54 Voltage detector, the Anode to the EN on the reg and the cathode to ground do it?· What do I look for to spec the thyristor?
I.e - the attached diagram!
thanks,
James
BTW, you will need a pullup on the EN pin.
Thanks for the info again - i'll get some bits and let you know.
J
One thing about SCRs is that they need a quite a bit of anode current to "hold" and the SCR in your circuit would need a low value pullup resistor in the anode circuit. But current is what you are trying to avoid. I don't think that circuit would work as intended.
If there is a micro like the Stamp in the circuit, maybe it can monitor the battery and turn itself off. When the "Start" button is pressed to apply power, the Stamp immediately makes a certain pin a high output which connects to the regulator enable pin to hold the power on. The Stamp reverts that pin low or input when it wants to turn itself off. There may have to be a pulldown R on the regulator enable.
Tracy Allen
www.emesystems.com
Thats a good idea! I like! There will be a propeller in-circuit so I can put an ADC in and then I get the option to do a "safe" shutdown before switching off.
cheers,
James
