Couple questions on Transitors and Mosfets
I have tried using both a 2N3904 and a 2N3906 transistor to turn on a 9.0V PMDC. With a 9V battery for power and the basic stamp at the base I am able to turn on the LED that is in series with the motor to ensure the switch is transistor is working. However, the motor will not turn on even though current is flowing through it. Is the voltage emitted directly related to how voltage I have at the base? How much voltage does the transitor eat up? Is there an advantage of using a pnp over a npn transistor without worrying about direction?
Also, what are the advantages/disadvantages of using a mosfet versus a transitor?
I know I asked a lot of questions and I appreciate the help.
can you draw out your schematic in 'paint' or something, and post it?
What's "PMDC"?
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Repeating Steve's exhortation, please show us your schematic.
Regarding your MOSFET vs. bipolar question: MOSFETs are voltage-driven devices; bipolars, current-driven. A voltage on a MOSFETs gate, with almost zero current draw, will cause it to conduct in such a way that it resembles a low-valued resistor. A MOSFET's disadvantage is that the gate voltage required for maximum turn-on may be higher than 5V. There are "logic" MOSFETs that are designed with lower turn-on voltages. However, in 3.3V systems, even these may be inadequate. Also, a MOSFET's gate can exhibit a high capacitance w.r.t. its source, especially if it's capable of carrying high currents. This limits the turn-on and turn-off speed, unless the gate is driven with specially-designed driver circuitry capable of high transient currents.
Post Edited (Phil Pilgrim (PhiPi)) : 12/5/2007 5:15:23 AM GMT
Since you mentioned 7.2 volts, my guess is that this motor is from an R/C car or possibly a cordless drill.· In either case, the motor will draw a lot of current.
Using Phil's schematic above, try powering the stamp from the 9 volt battery and use another power source for the motor.· If you have a spare wall-wart (try one rated around 6-9 volts at 900-1000mA) , you can try using that for power.· You can also try a 6 volt lantern battery for a motor power source.· Make sure you connect the negative wires from the two power supplies together.·
I hope this helps.
