Video overlay
I'm sure i've seen a thread which mentions this topic somewhere but can't for the life of me so i hope this hasn't been addressed already.··I'm wondering if it is possible to take an RCA signal from a camera and add a preprogrammed message and simple graphic(could be·just lines and circles) to it in real time using the prop.· I'm a pretty new to video signals so any pointers(no matter how basic they seem) would be greatly appreciated.
Prop based OSD module
http://forums.parallax.com/showthread.php?p=618061
OBC
Just getting started with Propeller?
Propeller Cookbook
PropDOS
To do color overlay requires a circuit that can "lock" onto the incoming color burst pulse. This is not an easy thing to do.
The HC-OSD pixels can have one of 4 states: transparent, black, white, or gray.
Bean
www.iElectronicDesigns.com
I've always used a multiplexer for switching overlay data in and out of the video signal, after it's been DC restored to keep the sync tips near ground. This gives me known voltage levels for sync, front- and back-porch, black, and white that I can match with the multiplexed signal from the computer. From there, the output is then buffered with a simple transtor buffer to restore the 75-ohm impedance.
Bean seems to have circumvented the DC restoration, multiplexing, and buffering in his design by using more of a forced superposition; so I'm wondering what, if any, assumptions he's making about the incoming video signal... Bean?
Post Edited (Phil Pilgrim (PhiPi)) : 12/7/2007 11:28:30 PM GMT
Recently there was a post here from Bean I think that described the MAX7456 chip, which seems to do B&W (only) video overlay. Looks good for putting time/date stamps and/or GPS data on a screen. Bean even had some breakout boards available, but when I inquired about how to buy, things fizzled out. I'll find the thread - but have to run right now. Here's the URL for the MAX7456 press release and technical page:
www.maxim-ic.com/view_press_release.cfm/release_id/1376
www.maxim-ic.com/quick_view2.cfm/qv_pk/5516
David
