ASM: Senior moments with CNT
Hi!
It seems, I do have senior moments with doing some math with CNT. Or the problem is somewhere else.
I do have a variable (lets call it OnCNT) that is -if some conditions are true- loaded with CNT (plus some offset we can ignore for now). right after that, an other variable (called OffCNT) is set with OnCNT + some offset.
In a loop, the variables OnCNT and OffCnt are checked and compared to CNT. If the CNT has passed bejond (or equal) OnCNT, some action is taken. If CNT has passed bejond (or equal) OffCNT, some other action.
Snipplett:
Hopefully so far so good.
Now to the comparison:
What's wrong with that? Is it wrong? And where?
I'm aware, that CNT and OnCNT/OffCNT will wrap over. The distance between CNT and OnCNT/OffCNT can only be much less than 1 second, so that can't be the problem.
The code I had for prototyping in SPIN worked and looked like this:
Thanks!
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Snipplett:
mov :OnCNT, CNT mov :OffCNT, :OnCNT adds :OffCNT, #SomeValue
subs CNT, :OnCNT WZ, WC, WR if_b jmp #:doSomethingElse
OnCNT:= CNT
OffCNT:= OnCNT + SomeValue
if (CNT - OnCNT => 0)
DoSomethingThatIsUsefull
Thanks!
Nick
YADRO
Paul Baker
Post Edited (Paul Baker (Parallax)) : 12/4/2007 12:28:30 AM GMT
And the "WR" doesn't change that? I mean, it shouldn't try to write, I only need the flags. Do I?
Nick
YADRO
Paul Baker
but didn't make it better.
If someone can confirm that this code is right, I'll have to chase bugs somewhere else ...
EDIT:
I think that adding the offset with "ADDS :OffCNT, #SomeValue" is wrong. I need the wrap-around.
I wonder how it worked in SPIN.
I'll have a sleep, it's 2 o'clock in the morning.8-/
Nick
YADRO
Post Edited (Nick Mueller) : 12/4/2007 1:18:32 AM GMT
CNT is "unsigned" - don't use SUBS until you understand the finer meaning of its carry
For "shadow registers": read my contributions... I think I explained it in detail (and many times...)
