interfacing the basic stamp to the 74ls373 latch
I am trying to figure out how to use this chip correctly, I though I had it figure out but I cannot get this circuit to work.
I am using the basic stamp board of education to breadboard this chip and interface to the stamp. I have the power and ground connections made, and then d0 - d7 doing to stamp pin0 - pin7. Then I have the latch pin 1 (OE) connected to stamp pin 9 and latch pin 11 (LE) connected to stamp pin 8.·
So I am trying to load data onto the data lines then latch the data in, then change the data on the data lines and then using a logic probe verify that the data stays the same on the latch output, since the changed data was never latched into the chip. But it does not appear to be latching my data, it just shows whatever is at the inputs on the outputs.
Here is my code
HIGH 9··· 'disable outputs
HIGH 8·· 'LE high
'load data onto latch inputs
LOW·0
HIGH·1
HIGH·2
HIGH·3
HIGH·4
HIGH·5
HIGH·6
HIGH·7
LOW 8··· 'latch data
PAUSE 500·· 'delay to allow latch to settle
HIGH 8·· 'finished latching data
LOW 9· 'enable outputs
HIGH 0 ' since pin0 was set low then latched into chip this value should not show up on latch output, but it does.
Here is my code
HIGH 8·· 'LE high
LOW·0
HIGH·1
HIGH·2
HIGH·3
HIGH·4
HIGH·5
HIGH·6
HIGH·7
Would you pleasepost your final code that worked? Thanks.
