The LED reflects off of an object in to the transistor. The Transistor is turned ON and it conducts.
The datasheet says the LED can take 50mA. With a Vcc of 5volts, you'll need a resistor equal to 5/50mA=100ohms minimum...I'd go for 120ohm resistor.
Put the resistor between Vcc and the Anode. Then connect the Cathode to ground (hope I didn't get that backwards....).
On the other end, you tie pin 4 (the collector) to a 1kohm resistor to Vcc. Then tie pin 3 (the emitter) to ground.
connect your stamp to pin4 (between pin4 and the resistor) and whenever you have an object reflecting the light, you'll see a low on your stamp.
Hope I got that right....
cheers
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ <FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
cheers
<FONT>Steve
