BS1 & XBee?
Hey Guys, Looking for the simplest and most inexpensive microprocessor that would work with the XBee. It may not even be a Basic Stamp, but I just need to communicate an "on-off" switch value through an XBee.
What would you recommend?
Joe
Joe
Since the BS1 is slow, you would need to configure the xBee to a low Baud like 1200.
An SX-28 prototype board would be the cheapest solution from Parallax, but a Propeller Protoboard
would also be cheap. You'd need a breakout board to mount the xBee on 0.1" hole centers (from
Spark Fun). The Propeller has the advantage of having a 3.3V regulator already on the board.
Truthfully, a PIC 8-pin processor would also do the job, could run at 3.3V.
- Stephen
