GPS to VGA code on Object Exchange
obex.parallax.com/objects/225/
I am trying to get the Parallax GPS printing to my terminal window ("PC_Interface") but I am a bit confused on how it works.
GPS_IO_mini has a "start" method but no parameter to pass it the pin Looking closer I see this:
with serXmit =0 and serRecv =1. The GPS unit only has 1 I/O that's bidirectional, so how does that work?
I'm new to the propeller!
uart.start(serRecv,serXmit,1,4800)
I had a look at that code, it is receiving on bit 1 and transmitting on bit 0. serXmit and serRcv are the parameters you were looking for. Are you sure that the module you are using has a single bidirectional pin?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 12/2/2007 6:15:26 PM GMT
