SD card file rename? — Parallax Forums
RaymanRayman Posts: 16,224
edited 2007-12-01 17:57 in Propeller 1
Anybody figured out how to rename a FAT16 file using fsrw or Femtofsrw?
It would be very convenient to have this ability right now for me...
    edited 2007-12-01 17:05
    It can't be done without modifying fsrw or Femtofsrw and writing a special routine to do it.
    First you have to make sure there isn't a file already with the new name, then you have to
    open the file under the old name, change the directory entry, and write it back. It's not too
    different from deleting a file, but somebody has to do the work.
    edited 2007-12-01 17:20
    Why not do this in two steps, and I think they are already there...
    First copy the file to the new filename, then delete the old file.
    IIRC, there is an example of copy & delete in Femto.
    OBC
    EDIT: yup thought I saw it in there... These could be adapted readily..
    Copy
                     ' COPY [noparse][[/noparse]<expr>],"<file>" or COPY "<file>",[noparse][[/noparse]<expr>] or
                     ' COPY [noparse][[/noparse]<expr>],[noparse][[/noparse]<expr>] where <expr> are different
                   if spaces == quote
                      scanFileName(@f0)
                      if spaces <> ","
                         abort @syn
                      skipspaces
                      b := getAddress(",") & !$7FFF
                      ifnot fsrw.checkPresence(b)
                         abort string("No EEPROM there")
                      if \fsrw.mount(spiDO,spiClk,spiDI,spiCS) < 0
                         abort string("Can't mount SD card")
                      if \fsrw.popen(@f0,"r")
                         abort string("Can't open file")
                      if fsrw.pread(@f0,32) <> 32
                         abort string("Can't read program")
                      if \fsrw.pclose < 0
                         abort string("Error closing file")
                      \fsrw.unmount
                   else
                      a := getAddress(",") & !$7FFF
                      ifnot fsrw.checkPresence(a)
                      if spaces <> ","
                         abort @syn
                      skipspaces
                      if spaces == quote
                         scanFileName(@f0)
                         if \fsrw.popen(@f0,"w")
                            abort string("Can't create file")
                         b := 0
                         if \fsrw.pclose < 0
                         \fsrw.unmount
    Delete
                  ' DELETE " <file> "
                   if spaces <> quote
                      abort @syn
                   scanFilename(@f0)
                   if \fsrw.popen(@f0,"d")
                      abort string("Can't delete file")
                   if \fsrw.pclose < 0
                      abort string("Error deleting file")
                   \fsrw.unmount
    Just getting started with Propeller?
    Propeller Cookbook
    PropDOS
    Post Edited (Oldbitcollector) : 12/1/2007 5:39:21 PM GMT
  • RaymanRayman Posts: 16,224
    edited 2007-12-01 17:38
    This may be naive, but can't one just change characters in the FAT table?· Aren't all the filenames stored there?
    Mike: Is this what you are saying?
    Rayman,
    That's essentially what I'm saying. It's just that you have to do it properly with the right error checking.
