[solved] Identifed a fried part on a Proto board. It was the Inductor.
Before I replace a part on this board I just want reassurance that I have the right part in the schematic. from the Proto board documentation it look like that is the 1uH resonator connected just before the servo connections. And If any one could provide more info on the part it would be appreciated.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Post Edited (Dgswaner) : 12/12/2007 3:07:48 AM GMT
DGSwaner
Just beware that you may start getting brownouts without the inductor in place. This just means that your Propeller and various logic circuits may reset due to voltage drops caused by high current draw.
EDIT: fixed bad grammar
Harrison
Post Edited (Harrison.) : 11/30/2007 9:06:08 AM GMT
The more I know, the more I know I don't know.· Is this what they call Wisdom?
The 5v and 3.3 regulators still work.
Fixed: Grammer
DGSwaner
Post Edited (Dgswaner) : 11/30/2007 4:05:53 PM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
It function in both directions.
Fuse and inductor
5V regulator have its short fuse but if one short after inductor it is to smal to short it.
And it blow upp.
Nothing is impossible, there are only different degrees of difficulty.
Sapieha
DGSwaner
Paul Baker
the mouser part I ordered is 81-LQG21NR10K10
DGSwaner
Paul Baker
Post Edited (Fred Hawkins) : 12/11/2007 11:15:03 PM GMT
Why am I changing the title to 'on the protoboard's inductor'? It was appropriately titled when I started the thread.
how does that work for you!
DGSwaner
I found this thread using search. I wonder why it does not show up in the regular forums listing as it was updated today.
Anyway, thanks for the information Paul.
James Ronald
My Robots
Post Edited (JamesRonald) : 12/13/2009 4:14:25 AM GMT
